Like Tree5Likes
SC10 4x4 Thread
Old 08-30-2012 | 01:42 PM
  #29026
CraigMBA's Avatar
Originally Posted by Jake S
well ordered the coupled clutch since i needed to spend another $6 to get over on free shipping on amain lol.
even says should be here saturday, so ill try it out on sunday if the weather holds off and family stuff doesnt interfere.
i think the coupled, ht pad inside, 19t front pulley will really help this truck outdoors. i tried the exotek clutch but didnt like that it was no slip, made the truck feel very inconsistent, but still loads better then stock inside pad.
If you disliked the exotech clutch, you're going to absolutely hate the coupled slipper.
CraigMBA is offline
Old 08-30-2012 | 01:59 PM
  #29027
Jake S's Avatar
it still has adjustability via inner slipper pad tho. which allows the front wheels to slip under hard acceleration, and not just balloon.
Jake S is offline
Old 08-30-2012 | 02:40 PM
  #29028
big_ads's Avatar
Originally Posted by ShortCourseOnly
2) When is it good to use overdrive? High bite tight or would it work for 8th scale tracks?
I have been playing with the overdrive the last couple weeks in practice. What I have found is that it is not very helpful on a big 8th track with a long straight. The back end of the car wants to pass the front end and it is hard to drive straight. On the in-field it seems to work ok, and on a smaller track without the long straight it worked pretty well.
Keep in mind I was using it with the exotek locker as well. Not sure what I am going to go with but am going to practice all day on monday and play with some more setup.
I am not sold on overdrive being "the" setup for the tracks I run on but did find that I was able to drive it as easily as the exotek alone, or just the VTS slipper and standard inner pad.
big_ads is offline
Old 08-30-2012 | 02:45 PM
  #29029
Wildcat1971's Avatar
you put a 19t pulley in the front. would that not make the front faster than the rear? if so, the rear should not over drive the front.
Wildcat1971 is offline
Old 08-30-2012 | 03:04 PM
  #29030
Jake S's Avatar
Questions for the thread:
1) What is needed to use the couple splipper hub? Is the 91180 Rear Top Shaft required?
yes it is required so the coupled hub "locks" into the top shaft, or if your feeling froggy with a dremel, can always go that route.
Jake S is offline
Old 08-30-2012 | 07:22 PM
  #29031
big_ads's Avatar
That is what I thought too, so i tried it. It jus didn' want to track very well at high speeds. Cant explain it, and maybe i had something else messed up at the same time. Its just the experience i had in practice, I havn't trashed the idea completely it just need some more work on my truck.
big_ads is offline
Old 08-30-2012 | 09:12 PM
  #29032
ryanpatrickgore's Avatar
what is the coupled slipper supposed to do? i guess i dont get it
ryanpatrickgore is offline
Old 08-30-2012 | 09:19 PM
  #29033
All wheels slip together
Old 08-30-2012 | 09:24 PM
  #29034
has any one tried the coupled slipper ? im still running the the vts slipper with the exotek clutch and i think it makes the belt slip more..
twisted is offline
Old 08-30-2012 | 09:41 PM
  #29035
I had no issues with the 19th front pulley on a long straight either, works great for me on a tight track.. it allows me to pull the car out of a turn or slide with a bit of throttle.
Arakon is offline
Old 08-30-2012 | 10:16 PM
  #29036
CraigMBA's Avatar
Originally Posted by Wild Cherry
On slippery surfaces or outdoors the pin works well, indoor clay no pin performs better ...
Apparently "Pink and two laps down" knows more than ROAR champ Ryan Maifield.
CraigMBA is offline
Old 08-31-2012 | 10:06 AM
  #29037
-WHEELMAN-'s Avatar
Dude... I see more people taking stabs at WC than a fat kid in Jr High! WTF!! If you don't like or agree with what he has to say don't say anything at all. You are why this thread is so full of BS! NO MORE!!!!!!!!!
-WHEELMAN- is offline
Old 08-31-2012 | 10:08 AM
  #29038
+1 I dont always agree with WC. But some people are being a bit mean. He is trying to help people and does not really bash anyone. He is just an AE true believer. maybe even a zealot. But he does not seem like a bad guy.
Old 08-31-2012 | 10:10 AM
  #29039
MantisWorx's Avatar
Craig is the reason???? Are you serious, where do you think it stems from? Its ok for Him to do it but no one else?
MantisWorx is offline
Old 08-31-2012 | 10:19 AM
  #29040
sigh..
anybody tried the new jconcepts 3D's? they are looking very versitile like you could run em in a few different types of track conditions. i bet they are great for my track when they get nice and worn in. (hard clay indoor)
