SC10 4x4 Thread
Huh...if its not the diff shims, belt or pulleys..check the the 26mm screw is in the correct spot in the front chassis brace/tranny case if its in one of the other 2 holes it will rub on the inner part of the front pulley.... have u checked the pinion?...maybe throw on a different one to if you still have click at the track..
Pinion is fine. I've never stripped a spur on this truck so that stuff is all good. I did change the spur for a new one for the hell of it.
If all else fails I will throw new gears in but this is not the original set. Been months since replaced so who knows, maybe.
It's not the metal sound of gears though. I recognized that immediately when I first got it and didn't know to limit travel and got the cone shim and gear clicking that follows. It's different.
Fresh clicker, fresh tensioner wheels & bearings, fresh belt, new spur, diff bearings, threw salt over my shoulder. If that doesn't get it I'm stumped.
5Likes
