Like Tree5Likes
SC10 4x4 Thread
Old 04-13-2012 | 01:55 PM
  #21376
Originally Posted by Evil Genius jr.
I thought the high traction starting point was 6?
It's all about preference, so just start with more than 5 on a high traction surface and less than 5 on a low traction one. Add or subtract until you like it.
Originally Posted by motobigalow
If I go with the rx8 are my 25c saddle packs going to put enough power out?
What motor and what exact pack?
Krio is offline
Old 04-13-2012 | 01:58 PM
  #21377
pro4 4000 or sc4x 4.5
the packs are genace 5000 25c saddles
motobigalow is offline
Old 04-13-2012 | 02:20 PM
  #21378
Suspended
Originally Posted by MattP
Ok so other than the center diff what else should I do to mine to bulletproof it?
Should I pick up the strc pulleys? Strc steering rack?
And what is a MTK slipper w/ garodiscs?
Also what's the deal with front springs on the rear? Can't you just order a harder spring for the rear and accomplish the same thing. What is so different about the front springs that make them worthy of putting on rear? Also what is the part number for the springs I would need for the rear?
I'm TOTALLY new to this truck so please bear with me if these questions have been asked before. I just want to know all there is to know about the truck before it hits the track again. My first run on my track was pathetic. I could have outran it with my old blitz. The truck was squirrely and all over the place. I couldn't put ANY power down at all without it looping out. I have since bought front and rear swaybars and some +3mm wheels so I know that will help the stability some.
Guess my post is being overlooked.
MattP is offline
Old 04-13-2012 | 02:21 PM
  #21379
You should be ok with the 4.5 sc4x on medium traction tracks, but I'd be weary of running that pack with the pro4. I had 40C gens ace stick packs that were ice cold with the 4.5 sc4x on high traction tracks, but they were hitting 110 degrees after I threw in the pro4 right when tekin released it.
Krio is offline
Old 04-13-2012 | 02:23 PM
  #21380
Evil Genius jr.'s Avatar
The STRC parts don't hurt but they are not absolutely necessary.
MTK slipper/ garodisk are just upgrades for the stock slipper which you will not use after the center diff.
The rear springs don't come stiff enough so people use the front springs which are stiffer. It helps the jumping a ton. #ASC91071
Evil Genius jr. is offline
Old 04-13-2012 | 02:43 PM
  #21381
ilanstylz's Avatar
Got bored and tried to test fit some of my rc8 springs onto the sc10. The blue, white, and red ones (not sure on green, don't have any) will not fit they won't even slide all the way onto the shock body, the yellow ones will but they won't fit the bottom ball cup right....... The only ones that fit decent were the black, silver, and bronze........ Even then it will probably only work in the front because the rears are way to long....... Here are some pics:
Front:
Rear:
ilanstylz is offline
Old 04-13-2012 | 02:45 PM
  #21382
evil genius you are saying the yellow ft springs aren't stiff enough in the rear? aren't the front springs shorter?
Old 04-13-2012 | 02:51 PM
  #21383
I upgraded from an RTR model.
Below are a upgrades I made and recommnend:
* Center Diff from rcshocks.com
* FT saddle pack bracket kit (inline saddles)
* +3mm offset wheels (JC Hazard or DE)
* FT chassis brace kit
* FT Ackerman steering link
* RPM arms (front and rear)
* Savox 1258TG servo
* Tekin RX8 & Pro4 4000 with 15/60 gearing
I run the following setup on a medium sized 10th scale outdoor dirt/clay track, medium traction:
* Blue front springs with blue front sway bar.
* Front shock fluid @ 32.5 w/ bladder, 1 x-ring, no shock boot, 6mm limiters.
* Outside front camber link location with 4mm ball stud shims
* Blue rear spring and blue rear sway bar (trying orange rear bar)
* Rear shock fluid @ 27.5 w/ bladder, 1 x-ring, no shock boot, 6mm external limiters.
* Inside rear camber link location with 1mm ball stud shim
* Diff Fluid 5/30wt F/R with slipper
* Diff fluid 5/7wt F/R with center diff
I tried a stiffer rear spring and did not like the way the truck handled.
As for jumping big jumps, getting a good run up to jump and then getting out of the throttle at the face works best to keep the truck flying long and low with correct attitude. Truck launches hard out of the hole and does not get loose coming out of turns hard on throttle. Stays consistant through fast sweeper and does not come around on itself. I can get hard on brakes and turn on a dime or drive it in hard and power slide through turns. Very consistant and predicatable mid-exit turning along with good on power steering. I have no added weight in the truck. It will sometimes traction roll in turns if I hit a rut. Will purchase Exotek chassis when off backorder. I do not see the STRC pulley as being necessary. The bigger issue is the bearings. Replace and keep an eye on condition as you should with all the bearings. I have already replaced the diff and hub bearings.
F_ME is offline
Old 04-13-2012 | 02:52 PM
  #21384
Yup!
The front blues are 4.3 the yellow rears are 3.1.
Old 04-13-2012 | 03:05 PM
  #21385
Yup!
Almost all trucks/buggies run softer springs in the rear compared to the front.
F_ME is offline
Old 04-13-2012 | 03:23 PM
  #21386
Suspended
Yup!
So I need to put the blue front springs on the rear. I will order those today.
Also how much is that center diff? Any big stores like Amain or tower stock it?
How much of a difference does that center diff make compared to the v2 slipper with heavy duty slipper pads?
MattP is offline
Old 04-13-2012 | 03:26 PM
  #21387
The center diff is 59.99 at rcshox.com and only available there. Marcus custom makes them.
Old 04-13-2012 | 03:30 PM
  #21388
SO....center diff or FT clutch basket ???? I have yet to have mine hit the track, but curious on any feedback from someone who can give an honest opinion.
dan-o is offline
Old 04-13-2012 | 03:36 PM
  #21389
ilanstylz's Avatar
As someone who has both, they are both great...... The FT clutch basket is far better then the original version......... However with the center diff v1 I still felt better power in turns then with the FT basket, so IMO with the new V2 center diff it can only get better........ The question you should ask is the price difference (about 40 bucks) a factor? Both will do the job but I think the center diff just does it better.........
Old 04-13-2012 | 04:26 PM
  #21390
JEFFs SC10's Avatar
when you get the exotek then put the blue fronts on, otherwise it'll be too stiff.
try the white fronts or green fronts in the rear for now.
I run the orange bar in the back and feel it's perfect.
JEFFs SC10 is offline
