SC10 4x4 Thread
I finally got my kit built last week, and when I hooked everything up, my steering is way out of whack, and the motor does not turn the belt.
So I disassembled the front enough to get to my steering servo, and fix the alignment on the servo.
Do I need to disassemble the whole front end and use the alignment tool to get the servo aligned back on the chassis again? I removed the servo to fix the steering alignment.
I am hoping that I tightened things too much on the belt and rear gears. I know that the motor works, because after I removed the belt, the motor did turn the gears.
I was so fustrated that I went out and bought the rtr Racers Edge Pro2 to get some driving in. The SC10 4x4 is my first RC vehicle, and I have been learning as I go. I can't wait to drive it for the first time. I had a blast on the Pro2, so I know the SC is going be more fun.
I finally got my kit built last week, and when I hooked everything up, my steering is way out of whack.
Then put the steering horn on straight up and down. Test your steering left and right... If it's set right... put some lock tight on the servo horn screw and tighten down the screw for the horn. Re-assemble truck. Also make sure you set your end points on your radio so that the servo isn't forcing past it's reach.
HI
Just got the FT kit yesterday, and found that a wrong part was given, instead of the steering bell crank, I got 2 of the servo alignment tool.
Just wanted to is am I the first one that lucky?
Cheers
Cheers
Maybe as far as getting 2 servo alignments, but several kits have been known to be missing parts etc, just call AE and talk to Chris Jaroz he'll send you out the part you need right away.....
Without the belt, you can spin the spur gear by hand, and spin the front pulley by hand, and the wheels turn easily, you probably just had the belt too tight.
They work great! Either their new Orange inserts or the AKA reds are a little softer if you need that. I normally like the supersoft compound for wet to dry clay. They have a new gold compound too but I have not tested that one yet.
That is the nature of plastic that is not glass or carbon filled. A common practice to combat this is to NOT store your cars on their wheels but rather on a car stand or as you will see most pro's do they take the tires off of their cars so no matter where they put them they rest on the chassis.
Certainly you can wreck a set of arms storing the car on the tires, particularly on a hot day.
In fact, I haven't seen this issue on any truck at our track either, or heard about it in forums aside from the SC10 4x4 arms.
5Likes
