Like Tree5Likes
SC10 4x4 Thread
Old 05-16-2012 | 10:45 AM
  #23281
Not sure what the garodisc material is, but looks like the old AE fiberglass they used to use for shock towers and stuff. Does it wear the slipper plates?
I should have ordered a set when ordering the v2 cDiff I suppose, not above trying new stuff. Obviously some(most?) of the "community" upgrades made it to become the FT version of the truck.
negatv1 is offline
Old 05-16-2012 | 11:31 AM
  #23282
Originally Posted by Wild Cherry
Twisted thanks for the extra info ,
Still think & hope I have right ...
Craig says no .. though ....
I read up last night with several different articles about roll center and their description were similar to your post...
No claim I'm a expert , but the Ae guys that showed us how to do this mod are far better then most ....
You have it right , buy the B4.1 carbon C hub tabs , invert & install then as shown in my picture...
Team kits already come with the longer studs , if you have standard kit you will need the longer 12mm stud.
tip ,glue each shim together building a 8mm stack first , makes it easier to install them under ball stud ...
thank you.
twisted is offline
Old 05-16-2012 | 12:13 PM
  #23283
rcmark17's Avatar
VTS tuning
ft wheels should pull almost as hard as the rear , my ride can make skid marks with both ft & back tires on carpet .
Been using the heavy duty pad on the ft drive...
I also run on carpet and agree the HD FT pads work just fine for all the high grip that I run on. Tried the FT VTS system out and it also worked great on the carpet and there was a big difference in the feel of the VTS over the stock system.
rcmark17 is offline
Old 05-16-2012 | 12:26 PM
  #23284
Originally Posted by vito
love this truck. had it in the street ran grate. the belt is not as tight as new its a good thing.
Good to hear... enjoy!
KewlToy is offline
Old 05-16-2012 | 12:44 PM
  #23285
Originally Posted by negatv1
Ugh.. The spirits do not want me to try out this new truck.
...the entire truck is practically built around the servo... I'm dreading having to basically tear down half of the truck to replace the servo...
after the scary experience of sc10 4x4 servo change virginity loss, the experiance becomes less painful, and for some, even pleasurable...
KewlToy is offline
Old 05-16-2012 | 12:46 PM
  #23286
Cain's Avatar
Tech Legend
just keep in mind, some servo's are bigger than others ... Might not fit ...
Cain is offline
Old 05-16-2012 | 12:54 PM
  #23287
Well the main concern is that all the screw holes become loose and sloppy from the frequent access.
negatv1 is offline
Old 05-16-2012 | 12:58 PM
  #23288
Not to mention any dirt that might be on whatever servo you put in its place. Make sure it's clean from any common contamination.
Krio is offline
Old 05-16-2012 | 01:27 PM
  #23289
CraigMBA's Avatar
Don't take my word for it, puppy killer. Like everything else, I suggest people do their own work. Print out this IMG, get out the magic markers and a straight edge, and model it for yourself.
Lowering the camber link equal amounts (similar to the hot ticket current modification on the B4.1) raises the roll center because it moves the instant center closer to the center line.
Raising the camber link equal amounts (smilar to the hot ticket current modification on the SC10 4x4 ) lowers the roll center because it moves the instant center further away from the chassis center line.
Full size race cars have moved away from changing the roll center as a means of changing handling a long time ago, mostly because changing the roll center has multiple other unintended changes as a consequence - bump steer and camber change to name two. Maybe changing the roll center helped, but the camber curve might be worse. Or maybe something else. In any case, it's just a guess as to why it worked or didn't work, at lease when compared to just changing the sway bar or making a shock valving change, which only changes roll stiffness.
Engineers hate to guess.
CraigMBA is offline
Old 05-16-2012 | 01:37 PM
  #23290
I noticed today while installing the FT upgrades that some of my ball links are not moving freely. They look clean and It's just a few of them, but i.e. the right steering link will just stick to any position I move it, it's that bad. I sprayed them with some graphite spray and it helped some, but still not as smooth as before. This is after just a few runs on sanded astroturf, no fine dust. Any ideas on how to fix them?
Arakon is offline
Old 05-16-2012 | 01:44 PM
  #23291
murky123's Avatar
maybe heating them up and poping them on and off for a few times, let hem rest and maybe it helped
murky123 is offline
Old 05-16-2012 | 01:46 PM
  #23292
Squeeze them with pliers.
Krio is offline
Old 05-16-2012 | 01:58 PM
  #23293
Evil Genius jr.'s Avatar
Whats the rest of your set-up ?
https://docs.google.com/open?id=0Bz8...U9vT094Rk1qT00
Evil Genius jr. is offline
Old 05-16-2012 | 02:09 PM
  #23294
I'll give it a try, thanks. Also, in the kit there was a golden screw.. any idea what that is for? All others are black.
Arakon is offline
Old 05-16-2012 | 02:11 PM
  #23295
Wild Cherry's Avatar
Tech Legend
Evil , that helps major ..
I think & just a suggestion
just
move rear shock inside on rear arm.....
after trying above, look more into the weight set-up your using , Ck Kody's Jconcept set-up weight layout....
Wild Cherry is offline
