Like Tree5Likes
SC10 4x4 Thread
Old 06-09-2012 | 03:46 PM
  #24781
JEFFs SC10's Avatar
Originally Posted by fq06
OMG, I dropped one in the living room rug and I spent 10 minutes looking for it. From rubbing the shag to hitting the bottom where it landed to picking the whole rug up and shaking and hitting it upside down. Nothing.
Then my friend caught a glimpse of it and asked if that was it... it was. Pure luck or I would still have 9 pins to tune with
haha me too. I dropped it literally about 10 inches and saw approximately where it fell but is f'n gone! Not even a magnet could find it.
Now I'm super anxious to give it a whirl now. Sucks that we've gotten about 5 inches of water this week.
JEFFs SC10 is offline
Old 06-09-2012 | 04:03 PM
  #24782
any one ever mess around with air ducts to the motor ? ya know instead of using a fan ?
twisted is offline
Old 06-09-2012 | 04:13 PM
  #24783
fq06's Avatar
Thought of that. My xxx-4 body has a duct above the motor, but it's mm's away from the motor.
With the sct bodies there is a lot of room between the body and the motor so I didn't think it would be effective.
fq06 is offline
Old 06-09-2012 | 04:30 PM
  #24784
jsamarin's Avatar
Originally Posted by SOuthernFRIED
Ok here's my setup..
Let me know how to get rid of the push
try moving your front inner ball stud to the inside hole. it helped with my on power push
Quote from JQ tuning guide:
5.7 Front Upper Link
The front upper link is a good tuning option on most cars. I will discuss a front upper link, not arm, but all of this applies to the cars with front upper arms also. Changing the front upper link changes how the car turns, responds to driver input, and how much traction the front end has.
In general, a long front link will make the car more calm, it will have more traction. A shorter link will make it react and change direction faster.
Lowering the front link on the tower will increase steering into the corner, but can also make the car flip over easier, specially while cornering. Raising the front link on the tower will make the car more stable, less steering into the corner. Going too high, may make it hook suddenly as the car slows down as the car is negotiating the corner.
Lengthening and shortening the link on the tower, or on the hub, has a similar effect. This is a bit of a hard nut to crack, but I feel, that the further in the link is on the tower, the more stable and consistent the car is. The further out the link is on the tower, the more non-linear, and inconsisten the car is, even if the length and angle of the link is kept the same. By nonlinear I mean, that it acts different at different speeds, or if traction changes, pushes, then turns, or similar. It will also roll less and have less traction. On the hub, it seems different, on the hub, it seems like it stays consistent, and the effect is more evident. A long link on the tower or hub is more stable, gives more traction, more steering mid to exit of the corner, and a short link is more responsive and gives more steering into the corner, and less overall traction.
jsamarin is offline
Old 06-09-2012 | 04:39 PM
  #24785
i was actually thinking of making a tunnel or a tube that would flow air to the motor from the front.
twisted is offline
Old 06-09-2012 | 04:47 PM
  #24786
JEFFs SC10's Avatar
southern fried I'm telling ya, move your front shock inward on the bottom!!!!!!!!
Old 06-09-2012 | 04:58 PM
  #24787
Southernfried, if you want more overall steering, get rid of the 8mm mod. That mod is designed to make the rear stay more planted, especially at high speeds. It still locks in the rear at lower speeds, just not as dramatically. I run 4mm spacers under the rear ballstud, this helps lock in the rear too, so, to free it up, get the inner mounting point as low as possible. When I ran on a high bite indoor track, I ran the C hub tower, but with no ballstud shims. Rear rotated like crazy, but the camber rise was too great. Go back to stock rear link setup, and enjoy!
rcmiket is offline
Old 06-09-2012 | 05:07 PM
  #24788
ilanstylz's Avatar
Well after only running the BH 120a esc for a day I put back my Tekin RX8, nothing wrong with the BH esc I just like how my RX8 performed better and considering I got my RX8 back from Tekin in just a little over a week (including shipping from CA to ID vice versa) how could I not run it with great customer service like that....... I also decided not to run it on the right side but to put it where the rx goes, now I just need to weigh it on my scales to see where I need to balance it out.
Oh and this is another reason why I'm running a full tekin setup, a good friend on here painted this body for me and I must say he did a great job.
ilanstylz is offline
Old 06-09-2012 | 05:24 PM
  #24789
SOuthernFRIED's Avatar
Wait whats the consensus? Inside of arm on frt? Back? or both?
Also I'm not changing the rear stud height unless all else fails. I didn't just mod it up to 8mm and say all is well. I started with zero under ball stud and it was undriveable. I have slowly added spacer's under the rear until it felt good..
Have considered making front camber rod longer, but my track has a couple of chicanes and I am afraid it will make the front end too "lazy" for lack of a better word. We have a couple of switchbacks that require a quick reacting suspension as well.
All in all my truck is good. This is the last piece of the puzzle for me and I really don't want to hurt one thing to fix another.
I truly appreciate all the advice, and I have a few options now to go thru. I will run it Thursday and see how it acts.
SOuthernFRIED is offline
Old 06-09-2012 | 06:00 PM
  #24790
CraigMBA's Avatar
Not enough air. I ran a Novak fan at first, not enough flow.
The yeah racing fan with the 180 in the part number works great. About $8.
CraigMBA is offline
Old 06-09-2012 | 06:02 PM
  #24791
CraigMBA's Avatar
The way you have it now is too stiff in the front. Move to the inner hole in the arm if you want to keep yellows.
CraigMBA is offline
Old 06-09-2012 | 06:12 PM
  #24792
I'm not tied to the yellow fronts. So what do you suggest Craig?
Old 06-09-2012 | 06:17 PM
  #24793
i was just thinking of doing something like that in case of fan failure or in place of the fan all together..
i was going to use a vortex style scoop. larger in the front and smaller at the end towards the motor to speed up the air flow. im just having a hard time coming up with a way to do it.
i did how ever put a strc finned motor plate on. should help a little.
twisted is offline
Old 06-09-2012 | 06:18 PM
  #24794
If you have under steer with the v2 center diff exiting corners, you need to go up on the number of pins you are using.
Originally Posted by kjohnsiii
I am running the exotek chassis with a pro4 4600 and no heat issues with the extra weight. The rx8 and pro4 are 1/8 scale work horses, just wish the rx8 was a little smaller though.
I heard that tekin is working on a sc speedo??
There is an RSX in the works that you can find in the onroad forum.
Krio is offline
Old 06-09-2012 | 06:39 PM
  #24795
JEFFs SC10's Avatar
you can do down to blue fronts to get more bite along with moving the shock inboard.
I'm telling ya you'll feel the difference on the first turn.
