Like Tree5Likes
SC10 4x4 Thread
Old 01-21-2013 | 07:44 AM
  #32281
Cain's Avatar
Tech Legend
Originally Posted by Bbradyc5
Will take it. Will save it for my next diff rebuild and curious to try it with an open mind and see how I like it.
If you are interested, I have about 40 pins for it, the newer hardened ones as well as an extra thrust washer and that blue spacer thing, all new. pm me if interested.
Cain is offline
Old 01-21-2013 | 09:42 AM
  #32282
MRCCC's Avatar
Rebuilt both my riffs using double shims under sun gear....two days at the track and they r making grinding sounds again under heave acceleration or braking!!
MRCCC is offline
Old 01-21-2013 | 09:43 AM
  #32283
vito's Avatar
i got a 150 bucks for my sc 10 4x4 kit
vito is offline
Old 01-21-2013 | 09:45 AM
  #32284
Cain's Avatar
Tech Legend
congrats vito.
MRCCC: Did you replace the gears or just reused the previous ones. Reason I ask is that its possible if you reused them, they were damaged enough that it more shims wouldnt' fix the issue.
Cain is offline
Old 01-21-2013 | 11:01 AM
  #32285
Wild Cherry's Avatar
Tech Legend
[QUOTE=vito;11707159]i got a 150 bucks for my sc 10 4x4 kit
I did the same and got a Ae Pro-Lite Vito ...
Wild Cherry is offline
Old 01-21-2013 | 01:42 PM
  #32286
hey guys, just purchased an sc10 couple weeks ago from a forum member. i have several fifth scale gassers but all the electric stuff is new to me. couple of dumb questions. it has a tekin rx8 and a traxxas velinion motor. running 4200 2s lipo battery. should i upgrade the motor? how much run time will i add if i get a bigger lipo battery. if i do change the motor what do i have to do to the esc? thnx in advance and sorry if these questions are stupid. im trying to learn.
jtphillips23 is offline
Old 01-21-2013 | 02:46 PM
  #32287
Is the Pro Lite better than the SC10 4x4?
coconut is offline
Old 01-21-2013 | 02:51 PM
  #32288
Tech Legend
Default Scotty Ernest SC Show Down Tour #1 @ TRCR Feb 8th
http://www.youtube.com/watch?v=j5ZuP...ayer_embedded#!
Old 01-21-2013 | 11:19 PM
  #32289
Tech Legend
Any ONE ?
Old 01-22-2013 | 05:32 AM
  #32290
MRCCC's Avatar
Originally Posted by Cain
congrats vito.
No. No. No....New gears of course, and New cases beacuse i had the stock copper case, all new!! the only thing I reused were the outdrives I even put new bearings, 20k oil on front and 5k rear.... two shims under each sun gear!
The noise went away the first two days at the track then its starting to come back little by little only under high torque. Im going to take them out again and examine the gears I wish AE would make them out of a more durable metal.
MRCCC is offline
Old 01-22-2013 | 05:38 AM
  #32291
MRCCC's Avatar
[QUOTE=Wild Cherry;11707539]
WC does the prolite use the same diff as the sc10 4x4
MRCCC is offline
Old 01-22-2013 | 05:41 AM
  #32292
MRCCC's Avatar
nevermind just went on the AE site and saw they are not the same diffs I dont know the prolite just looks kind of cheap to me.
MRCCC is offline
Old 01-22-2013 | 05:55 AM
  #32293
Tech Legend
A lot of the RTR parts can use a aftermarket upgrade ..
Expecting to see lots of new parts soon as this ride is going to get a whole lot more popular due to its performance on the track ...
Its not that expensive to build one and its speed on the track can't be matched by any other design .
I sold the old Sc10 , RTR ESC , Motor & body for a total of $230 off the $350 price ..
Have purchased to build as seen
Sc10 12mm shocks , Ti Rods , Losi HD ball cups & stud, serrated wheel nuts , JConcept battery strap .
Pro-Lite = lighter , shaft drive , lower center of gravity....
Old 01-22-2013 | 06:14 AM
  #32294
Is this good combo, for sc10 4x4? Cheap it is, but have someone test this motor or esc.
http://www.hobbyking.com/hobbyking/s...or_5135KV.html
http://www.hobbyking.com/hobbyking/s...nsorless_.html
jonu93 is offline
Old 01-22-2013 | 06:25 AM
  #32295
The ESC should be fine, but I would go with this motor:
http://www.hobbyking.com/hobbyking/s...550_size_.html
indybobb is offline
