Like Tree5Likes
SC10 4x4 Thread
Old 06-09-2012 | 10:09 AM
  #24751
kjohnsiii's Avatar
Originally Posted by Supernootz
Thinking about getting the EXOTEK LCG Chassis. I heard it adds 5 ounces down low (sounds great)!
My question to those of you that use it: What do you have to adjust, relative to how it was before this upgrade, in terms of pinion size (does the motor run hotter with the extra weight?), slipper setting, shock springs, oils, sway bars? Obviously sag has to be re-set, but what else? Or do you just leave it as is and enjoy the extra weight?
I'm curious also if the extra weight beats on the gears or belt any more that stock.
I am running the exotek chassis with a pro4 4600 and no heat issues with the extra weight. The rx8 and pro4 are 1/8 scale work horses, just wish the rx8 was a little smaller though.
I heard that tekin is working on a sc speedo??
kjohnsiii is offline
Old 06-09-2012 | 10:45 AM
  #24752
Originally Posted by SOuthernFRIED
Thanks guys, next race is Thursday, I'll try the suggestions then. Truck really is good except for the push!
FQ, general on power push in and out.. As long as i'm off throttle all is well. When I get on throttle it starts to push. I catch myself letting off the throttle anytime I need to turn. I have to get it pointed right before I can get back on the throttle.
Check your rx8 settings too, don't recommend any push control. Also what helped me was throwing in the overdrive pulley in the front. Seems to help the back of the truck follow the front instead of the rear pushing the front around like a snow mobile.
Shins is offline
Old 06-09-2012 | 10:52 AM
  #24753
Evil Genius jr.'s Avatar
Will the overdrive be okay with the c-dif?
Evil Genius jr. is offline
Old 06-09-2012 | 11:08 AM
  #24754
I guess ask Marcus on that one, I have a clutch basket. I don't think the c-diff will solve the heavy rear issue our trucks have but definitely should put more power down instead of loosing it.
Shins is offline
Old 06-09-2012 | 11:41 AM
  #24755
CraigMBA's Avatar
No - it will diff all the time.
CraigMBA is offline
Old 06-09-2012 | 11:46 AM
  #24756
fq06's Avatar
Quickest & easiest change is as Marcus suggested, move the shock mount location on the rear arm to the inside. Too much rear traction may be adding to the push prob.
Not there yet, less front camber... possibly down to -1.
If that doesn't get it, try reduce the amount of toe out to where you are getting the exit steering you want but still have good initial turn in. That's a give & take. (courtesy of Marcus)
fq06 is offline
Old 06-09-2012 | 11:50 AM
  #24757
JEFFs SC10's Avatar
moving shocks inward on bottom makes a big difference.
JEFFs SC10 is offline
Old 06-09-2012 | 11:52 AM
  #24758
fq06's Avatar
I forgot, you running the C-Diff? More pins may help balance the power front to rear. pins like a thin front diff fluid for better steering in loose conditions and more pins if you are running on a high traction surface.
fq06 is offline
  #24759
darryl80's Avatar
Talking
i cant wait until i get my brand new sc10 4x4 factory kit truck next week i am very very very very excited.
darryl80 is offline
Old 06-09-2012 | 11:58 AM
  #24760
SOuthernFRIED's Avatar
I do have great rear traction. Have discussed reducing rear traction to balance the truck, but i'd rather try to improve the front first. I'm gonna reduce all my camber to -1 and move the rear shocks to the inside arm mount. I'll start with that. If I can fix the push the truck will be damn good.
fq, have the v2 center diff with 5 pins at the moment, have been considering the move to 6.. Medium traction, outdoor track.
Ironically,I have the complete opposite problem with my SC10 2wd at the same track. Turns perfect but can't get the rear to hook up! As it is I am still running lap times as fast as anyone else. If I could get the rear of the 2wd hooked up it would be perfect.
SOuthernFRIED is offline
Old 06-09-2012 | 12:11 PM
  #24761
SMR 510RR's Avatar
Go to no toe or toe out...That should help a bunch too and its easy to change.
I just got my GF's sc10 2x dialed in, added weight behind the battery and made the front end sky high and not only it is way faster but easier to drive.
SMR 510RR is offline
Old 06-09-2012 | 12:13 PM
  #24762
I run 1 degree toe out on everything, SC10 2wd already has rear ballast weight in front of tranny, + 3oz. in rear of bat tray.
Old 06-09-2012 | 12:31 PM
  #24763
fq06's Avatar
Adding and removing pins is another quick and easy tool. I find myself with about the same setup indoor & outdoor (except ride height) and just change the number of pins.
If the outdoor track is real blown out I gotta mess with other stuff, but from loose track to high bite I just change the pin count... easy.
fq06 is offline
Old 06-09-2012 | 12:39 PM
  #24764
How many pins are you using? I have no problem getting traction with 5 pins. My outdoor track is pretty smooth after it was redone. I started with 4, moved to 5... now what do ya think 6?
Old 06-09-2012 | 12:45 PM
  #24765
fq06's Avatar
Try going the other way, more pins should put more power up front.
Maybe to get a feel of it, run a pack with no pins and run a pack with 10 pins.
fq06 is offline
