Like Tree5Likes
SC10 4x4 Thread
Old 01-22-2012 | 04:48 PM
  #15526
Chad Smith's Avatar
Originally Posted by Evil Genius jr.
Thats what I have too.
Yes, I am going Saturday, not Sunday though.
Cool see you there!
Chad Smith is offline
Old 01-22-2012 | 04:51 PM
  #15527
symmetricon's Avatar
Originally Posted by lodhammerdin
Sweet, thanks. I don't run the boots either.
No prob. Here in Houston, we have some nice narly 1/8 tracks with some big air time. If you happen to land and the truck isnt flat, you can bend the cva by compressing the shock more than it does when the chassi bottoms out. It has happened to me 3 times untill I added enough limiters.
symmetricon is offline
Old 01-22-2012 | 04:56 PM
  #15528
BlueGlowBoy's Avatar
Originally Posted by Thomas P
Strange i have the small black rubber washers on my shockshafts..and i do not use anytgi. Else and i have maximum out and up travel, and cant see any mark on my rear arms...
I felt the same way when I first heard about this problem. No matter how far I pushed my truck down, it wouldn't bind.... Then someone reminded me that when your truck is going around a corner, it leans over and your suspension can travel farther than if it is just pressed flat against your pit table....especially if your corner is rough. You can also land slightly crooked, and have a single wheel travel way beyond the range of landing on all 4 wheels at the same time.
To prove it to myself beyond a shadow of doubt, I took my shocks off, turned my truck upside down so that the suspension would travel all the way up, and slowly rotated the wheels. Sure enough, when the slots in the outdrives went vertical, the dogbones dropped into the slot and bound up. Seeing that, and then reassembling my truck, I can see exactly where it happens through normal racing.
BlueGlowBoy is offline
Old 01-22-2012 | 04:59 PM
  #15529
lodhammerdin's Avatar
Originally Posted by darryl80
i just bought a sc10 sct a few hours ago. need to find a good servo for it.
Jr 9100HVS. .06 60° and 230 in oz tq. I love this servo.
lodhammerdin is offline
Old 01-22-2012 | 05:03 PM
  #15530
Here in el paso, the track isn't as nice, hell, my back yard track at home is 10x nicer than alot of places I've ever raced at (check my threads started if your curious). Plenty of big air jumps with the same possible issue with not landing flat. I did the same thing with my limiters and then added another thin one in the front.
Old 01-22-2012 | 05:07 PM
  #15531
Chad Smith's Avatar
Any pics of your backyard track need some idea's when I build mine
Send me a PM so we dont junk up the thread if you have any pics.
  #15532
Cain's Avatar
Tech Legend
does anyone use the front clicker other than set to full time 4wd?
Cain is offline
Old 01-22-2012 | 05:27 PM
  #15533
Chad Smith's Avatar
I really dont think many people use it. Some people even CA there clicker togethor so it doesnt come apart. I guess you could play with it to see if it fits your driving style and track.
  #15534
vito's Avatar
are the ft wheel hexs a must have ?
http://www.amainhobbies.com/product_...um-Wheel-Hexes
vito is offline
Old 01-22-2012 | 05:33 PM
  #15535
Mizchief's Avatar
Depends on your wheels. If your wheels are tight and commonly pull the hex off the pin, then they will save you a lot of headache. I bought some to tighten the fit on my proline wheels, but didn't' make much of a difference.
Mizchief is offline
Old 01-22-2012 | 05:36 PM
  #15536
vito's Avatar
can i get a link to some good rims ty?
vito is offline
Old 01-22-2012 | 05:47 PM
  #15537
n8b
I've seen some guys use it loose on carpet to help slide around the tight corners.
n8b is offline
Old 01-22-2012 | 05:52 PM
  #15538
Cain's Avatar
Tech Legend
Thanks. i liked the feel of it back in the day with my losi xx4 and the Academy SB V2 buggy. May give it it a shot and see. If I recall correctly, this would give a lot of steering off power?
Cain is offline
Old 01-22-2012 | 05:53 PM
  #15539
CoyoteSlash's Avatar
www.TowerHobbies.com
CoyoteSlash is offline
Old 01-22-2012 | 06:01 PM
  #15540
Chad Smith's Avatar
