Like Tree5Likes
SC10 4x4 Thread
Old 01-16-2012 | 05:58 PM
  #15076
blakelenk521's Avatar
Originally Posted by murky123
http://www.reedypower.com/products/details/925/
im thinking about this motor to replace my castle 1410 3800kv.
I really love my 1410 but want a new motor as back-up.
I do not wish for a huge 550 or 4-pole that draws massive amps.
I like the specs of the 550-sl 4000kv
Max. Efficiency Current: 10 / 50A
Max. Surge Current: 60A
any thoughts? or experiance with these ?
I love to hear it.
I ran this motor for a while and it definatly is a great motor. It did everything I wanted it too and more. It doesnt studder either off the start. I changed it with a tekin rx8 and a sc4x 5.5 and didnt see much improvement but the tekin still has the far edge. Nun to less this is a great motor and is very durable and powerful with the right gearing and batteries. Dont expect Tekin Pro 4 power tho.
blakelenk521 is offline
Old 01-16-2012 | 06:21 PM
  #15077
wfdfiremedic's Avatar
Originally Posted by Manatarms25
What's everyone's thoughts on the RTR electronics (ESC / Motor only) for the causal racer. I am strongly thinking of coming back over from the SCTE.
Very smooth. Zero cogging. Medium speed. Not the fastest, but fine if you can drive. in honesty, I was very impressed with the stock electronics. Let's not forget the battery makes quite a difference as well. The stock servo is ok. With a bec it is a tad better. Honestly, it depends on your driving ability.
casual racer..fine...imo
wfdfiremedic is offline
Old 01-16-2012 | 06:26 PM
  #15078
johnbugman's Avatar
Default My apologies sir!!!
First off let me apologize for the rude turd boy comment. I was out of character on that comment!!! As far as your mamba problem, Im sure I can lend a hand! First off, are running a external bec? Second did you disconnect the internal bec if you are running external bec. If not you can cook things over time and this will surely lead to malfuctions over time.
johnbugman is offline
Old 01-16-2012 | 06:34 PM
  #15079
Default JConcepts Hazard Wheels
I just bought a pair of JConcepts Hazard wheels and noticed that their are hairline cracks at the inside hub. I Checked the 2nd pack and same thing. I took them back to the shop I bought them at to exchange and two other packs had the same hairline cracks. Are any of you having problems with these wheels and or noticed similar issues?
F_ME is offline
Old 01-16-2012 | 06:40 PM
  #15080
johnbugman's Avatar
I just checked my hazards and yes they have lines in them too. Looks like moldlines in my opinion. Just pulled them out of the package.
Old 01-16-2012 | 06:47 PM
  #15081
johnbugman's Avatar
OK I want to be judged hard on this run, give me honest opinions. Here is some practice laps on a large track with huge 1/8 scale jumps! I think the truck jumps well given the track conditions. Also wind was blowing 25 miles per hour constant. Here's the link http://youtu.be/vtia6gQFcUc
Old 01-16-2012 | 06:48 PM
  #15082
vito's Avatar
i just bash can i just lock the slipper down?
vito is offline
Old 01-16-2012 | 06:50 PM
  #15083
Awesome thank you for the feedback.
Manatarms25 is offline
Old 01-16-2012 | 06:55 PM
  #15084
johnbugman's Avatar
Just listen to slipper action.... It should slip for 2 to 3 feet in general. thats a good safe setting and you will get good wear out of the pads for general bashing/driving.
Old 01-16-2012 | 07:05 PM
  #15085
They are not mold lines. Those are definitely cracks on the inside hub.
I checked 4 sets of wheels and they all had them in different places around the inside hub. As much as I like these wheels, I hate to waster a new pair of tires if the hubs crack through.
Anyone have a problem with JC hazard wheels cracking at the hub when running?
F_ME is offline
Old 01-16-2012 | 07:14 PM
  #15086
Chad Smith's Avatar
The truck definatly jumps well. It seems like the track was slick or you where not running the right tires. I would say take the turns alot tighter and closer to the pipes. In a race, it would be easy to make a pass in the corners when you take them so wide. Other than that, practice practice practice!
Chad Smith is offline
Old 01-16-2012 | 07:17 PM
  #15087
vito's Avatar
looks like i dont need a basket. i just need sway bars rpm a arms brace and thats all thanks
vito is offline
Old 01-16-2012 | 07:24 PM
  #15088
rcjunky10's Avatar
For your application I wouldnt spend the money on the sway bar kit. The sway bars really are a tuning option for when racing. The other items you listed are worth the money.
rcjunky10 is offline
Old 01-16-2012 | 07:25 PM
  #15089
vito's Avatar
i like to pay in the street
vito is offline
Old 01-16-2012 | 07:31 PM
  #15090
johnbugman's Avatar
thanks yes actually the truck only turns well to the right where the battery sets. Im running the stock battery placement which makes the truck right heavy and it only turns well one way. Ya the truck is jumping well do to mantisworks dual stage pistons and some schooling from you guys on here! sweet! Im not running saddle packs or any of that hightech set ups just looking to see the full potential of how it was designed to run from factory. Im going to run some weight to offset the heavy side which it needs. I just need to invest in 4 light scales to weigh the truck on.
