SC10 4x4 Thread
Marcus, it was me a few pages back asking about footage of your rig on a "true" 1/8th scale style layout as I want to see the pistons going to work on large features. Ive watched all the vids that you've posted to date but all the tracks "seem" to be relatively flat with very few if any large features. Do you have any footage showing your setup being really taxed by a big supercross style track? Here is my layout:
www.capefearraceway.com
Some other that come to mind would be:
- Nor Cal Hoibbies
- Revelation
- The Nitro Pit
Thanks Marcus!
- Nor Cal Hoibbies
- Revelation
- The Nitro Pit
Thanks Marcus!
I just finished building my a brand new kit yesterday, I noticed the wobbly out drives in the rear also. I haven't ran it yet, i'm planning on taking it apart again today to try and figure out why.
Also my thrust spacer wouldn't fit over the top shaft , one side of the spacer was tighter than the other.
Dammit. It does it with the Other motor too.
But works fine with my 1410/1415. So the Sensor deal on my MMP must be bad? That really blows.
~Tried older firmware
~Tried two sensor wires
~Tried Sensor only
~The MMP won't even jingle it's little arming tune, but the lights arm.
~Tried Sensor only
will the pro4, or redline motor work correctly with the sensor wire unplugged? A couple years ago i was trying to run a ballistic 550 4.5 off an mmp, and it would do the same thing you are explaining with the sensor wire plugged in, but with it unplugged, it would cog a bit off the line, but fuck right off once you pored the coals to it. It turned out to be a bad sensor port, and castle warrantied it for me. still sold it for an rx8 though, which im still running now
+1....you can't put a price on piece of mind!
- Nor Cal Hoibbies
- Revelation
- The Nitro Pit
Thanks Marcus!
- Nor Cal Hoibbies
- Revelation
- The Nitro Pit
Thanks Marcus!
I've got the pistons and center diff.
I'm curious how tight People have the slipper set. I realize this setting is very specific to each truck and track conditions. Also, I know it is something that can be tested on a high grip surface. Regardless, I was wondering how much of the screw is showing on your setup. I have the clutch basket and garodiscs and the stock RTR brushless motor. I have about .5 mm of the screw showing.
From: Norwood, OH...and CCRCR and The OhioRCFactory
This changes everything for some ....
New Ae Graphite plastic , new stiffer chassis , arms ect ...
No more brace needed.....
New Ae multi slipper system ....
Team shocks, Ti Rod's, ect ....
All I know so far , cept ....
Maybe available real soon , like next month or so....
Remember !!!
You heard this first on RcTech .....
Remember !!!
In a year
5Likes
I double shimmed and added 5mm of up travel limiters to no avail.
