SC10 4x4 Thread
#7576
Which is the better upgrade screw set for the SC10 4x4?
http://www.amainhobbies.com/product_...teel-Screw-Kit
OR
http://www.amainhobbies.com/product_...inum-Screw-Set
OR
http://www.boltdepot.com/
#7577
i could see upgrading the screws if you were building a show truck or something of that nature but since most of us race or bash these trucks why upgrade the screws, they seem to be of good quality and there are so many other upgrades that would improve the truck...just my opinion....
#7580
When installing the blue ball things into the sway bars (Step 1 of the sway install) did anyone else have issue with getting them to go in without crusching the soft alluminum? I tried using a set of flat pliers that are adjustable so that I was pushing on it as straight as I could, and they still deformed enough that I cannot use them...
#7581
#7583
http://www.lefthander-rc.com/catalog...e.php?pID=1708
I had one I use for my oval car, but if I didn't, I'd improvise my own press and make something out a 3mm screw, a couple of washers, and a nut.
#7584
#7585
just finished putting my sway bar kits on,a little lube and a 7mm nut driver and the balls pop right in with minimal effort. how much of the bar do you have sticking out of the holders? i made mine even with the end of the piece. used the blue bars to start.
#7587
can someone please let me know what size carbon tube i need to make the center brace? I know it is in the last 250 pages but its getting late.
I remember the rc8 shock ends and the 4-40 threaded rod, but that pesky carbon rod.. i can't seem to recall......
ben
ben
#7588
HERES MY TRUCK VIDEO ! nothing you haven't seen before lol
pro4 installed !
http://www.youtube.com/watch?v=Ia5kFscEx-k
pro4 installed ! http://www.youtube.com/watch?v=Ia5kFscEx-k
#7590
Motor's, tenshock 4000kv or castle's 3800kv
Should run you about 150-180 depending on if you buy new or used......
5Likes
