Thats all I've been running lately and wouldn't second guess my decision I've had multiple wins with the combination and feel its the perfect tight track combo with the torque that the motor/speedo boast. Also I haven't had one failure and thats more important than anything to me
Does anybody have experience with the Hobbywing 3656SD 4700Kv motor in a SCTE ?
Argh!!! You just reminded me that you only get TWO o-rings in the shock rebuild pack!!! Ridiculous! Why can I buy a TLR 22 Oring pack with 8 o rings in it and I can't get the same thing for the SCTE!!!
Outrageous!
This has BRIEFLY made me forget about popping ball cups on my 22SCT
Outrageous!
AWESOME, i was looking at those and the CF ones i saw on ebay
Yes, much more power on the 4600 or 4700kv from HW that i have, just uses more juice so plan to run a higher C rating battery if goin to these motors, i run 65c and all is well and puffed the 40C from gens ace but this is also where the battery quality will show as the cheaper packs might puff but my cheap nanotech 6600's have been great and very happy
Yes, currently the only motor i have and its been great, geared at 13t on the SCT Pro combo and ive never looked back..
I took apart my scte and inspected my axles, and the ends look a bit wallowed out.
Are axles just a part that needs replaced from time to time?
Are tekno more durable? Are there direct replacement teknos?
Axles and drive shafts are wear parts. If you are talking about the cross pin holes in the axles there are two sets of holes so you can move to a new hole and tighthen them up again!
ya im running the 4000kv on a small tight track and its just enough, outdoor or bigger track it would not be enough. also using the gens ace 5000, 50c, seems to be a good motor, only 3 races on it... but i will get the 4600 for bigger tracks....
+1 my tenshock has been fantastic. The only downside is just like hobbyking and there lipos, the customer service is terrible.
I was wondering why I found so much posts and youtube videos about the Tenshock 411, and hardly anything about the HW 3656SD.
I'd love to see a race with a Scte with that motor in it just to see how it performs.
That's good to hear since I ordered it yesterday (Will probably take a month to get here from Hong Kong though...)
Just my 2 cents.
Yes there are direct replacement Tekno shafts for the centers and front/rear. I'm currently running them on my SCTE for quite a while and haven't had a failure. I have bent of one the rear shafts but I also splintered a losi shaft in the past and the drive pin slid out and tore apart my rear case. I have heard of people having them bind up but it seems different from SCTE to SCTE because I personally didn't have a problem.
Just my 2 cents.
Just my 2 cents.
Seems that would occur more with chassis flex, and I assumed the MIP setup would be a bit more stiff with it's brace. I know I bent one with the stock chassis and stock plastic brace.
