Like Tree9Likes
Old 09-09-2012, 02:17 PM
  #39181
TCCustoms's Avatar
Originally Posted by rcus3r
Been running the RTR on 3S. Looking to jump the ship onto the 2S, high kV motor setup.
ESC question. Is there a ‘must have’ programming feature the RX8 has that the Losi/MMP or the SCT Pro don’t have? I am already familiar with Castle Link programming and all those features.
Thanks.
The one difference that i kno of w/o knowing all the settings on the RX8...The RX8 has what is called a "CURRENT LIMIT" which actually stops power output at whatever percent you have it set at TO WHERE the SCT Pro has a "PUNCH" setting which changes the initial power output when the trigger is pulled to whatever setting and controlling the initial punch but still allowing full speed/power.
Personally i like the current limit of the RX8 and can help control heat issues but i paid as much for my Hobbywing SCT Pro and HW 4700kv ESC/MOTOR combo as you will for the RX8 so depending on what your budget is...can play a roll but my gear keeps up with the Tekin and im more than happy with my decision and would do it again, only downfall is warranty from HW but no problems here.
ENJOY
TCCustoms is offline
Old 09-09-2012, 02:18 PM
  #39182
Gene158's Avatar
How would this combo be in the scte? Also, how would it compare to the rx8/pro4 4600kv performance wise?
http://www.amainhobbies.com/product_...le-1406-4600kV
Gene158 is offline
Old 09-09-2012, 03:11 PM
  #39183
rcus3r's Avatar
ENJOY
Thanks. Castle has bunch of settings, labeled differently, but probably do the same thing - punch contorl, motor based torque limit, timing, and start power.
rcus3r is offline
Old 09-09-2012, 03:20 PM
  #39184
I don't think that motor will be enough, it's a two pole I think, the pro4 is a four pole, esc would be ok with an external bec, IMO there's better options.
jnyrcr is offline
Old 09-09-2012, 03:38 PM
  #39185
TCCustoms's Avatar
ahh, "start power" sounds like my "punch" setting
But with the LCD programmer there is roughly 10 settings total
Old 09-09-2012, 04:43 PM
  #39186
Gene158's Avatar
Thanks for the input! That motor is actually a 4 pole. I'm trying to find an alternative to the tekin combo (pro4 4600/rx8). Something with the same power and speed but less expensive. Others have suggested the tenshock sc401 but I'm wondering how it stacks up to the pro4 and what esc to pair it with.
Gene158 is offline
Old 09-09-2012, 05:14 PM
  #39187
HighLife420's Avatar
Trader Rating: 49 (100%+)
I know a few people who run a tenshock and a hobby wing ESC and have been doing pretty well.
HighLife420 is offline
Old 09-09-2012, 05:18 PM
  #39188
Slotmachine's Avatar
That motor would be plenty.......................but it would be nice to have a sensored motor to take advantage of the extra boost settings in the speedo. A 15 tooth pinion should be good for most larger tracks.
Slotmachine is offline
Old 09-09-2012, 05:40 PM
  #39189
TCCustoms's Avatar
Hobbywing SCT Pro and HW 4700kv here on 13t and loving it, plenty of grunt even with punch on 1, thats what i have it set on and paid just under $200 shipped from FalconSekido.com Comes with programmer, 2 pinions, wiring and all that jazz
Old 09-09-2012, 06:38 PM
  #39190
TimMo846's Avatar
I'm looking to get an scte and pretty set on a pro4 (4600) with an rx8. However that combo is definitely expensive so I'm wondering if there's another motor/esc combo that can run with the tekin without breaking the bank. Nothing crappy, just something a little less expensive.
http://builtrc.com/tenshock_sc401_4600.aspx and http://www.brushlesshobbies.com/120A...mer_p_113.html , I run the lt4 with the pro4, the tenshock gets allot of good reviews, hope this helps.
I just got my tenshock 411 4600 and raced it today, I have to admit it's a BEAST motor!. I let a few of the other guys with the Tekin Pro4 in their Losi's and they said they will be ordering one very soon. So I would say for the money it's equal if not better.
TimMo846 is offline
Old 09-09-2012, 06:53 PM
  #39191
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
I must agree got to love the 4600 sc411..... tremendous power and a price point to boot... running it with my SCT Pro esc and temps are great!!!
BlackStarRacing is offline
Old 09-09-2012, 07:13 PM
  #39192
TimMo846's Avatar
Also, the Toro ESC would be a good budget ESC as well. http://builtrc.com/toro_sc_esc_120_amp.aspx
I run the Tekin RX8 ESC with the Tenshock 411 4600kv motor and it's great, but I already had the RX8 from a previous 1/8scale.
TimMo846 is offline
Old 09-09-2012, 08:22 PM
  #39193
Gene158's Avatar
Seems like a good combo. Does it come with a signal wire and everything else you need? Also, do you have to run an external bec with that combo? I know some people were saying the bec on the hobbywing was insufficient.
Gene158 is offline
Old 09-09-2012, 08:31 PM
  #39194
TimMo846's Avatar
The motor comes with a sensor wire, I'm not sure if the ESC does. It's always a good thing to run a BEC on your receiver to prevent any power loss, especially with ESC / motor combos and servos that draw a lot of current.
TimMo846 is offline
Old 09-09-2012, 09:03 PM
  #39195
rcgod's Avatar
Trader Rating: 33 (100%+)
I have the sct pro and 120 xerun and the internal bec has been fine with a jr9100s servo and dual fan on the motor.
rcgod is offline
