hey guys,
i just got my whole setup soldered and ready to go but i just tested it and something is up... the steering is glitching really bad and the truck wont start out by itself unless is push it first then it runs normally. when it does start by its self it cogs really bad. im thinking i might need a BEC because of the high powered servo but i wanted to see what everyone thought... maybe change some RX8 setting?
my setup is:
SCTE
tekin Pro4 4600kv
Tekin RX8
savox 1268tg
spektrum receiver and transponder
i tried a bunch of different batteries all of them were fully charged 2s and 4s
Thanks!,
Dan
my setup is:
SCTE
tekin Pro4 4600kv
Tekin RX8
savox 1268tg
Thanks!,
Dan
hey guys,
my setup is:
SCTE
tekin Pro4 4600kv
Tekin RX8
savox 1268tg
Thanks!,
Dan
my setup is:
SCTE
tekin Pro4 4600kv
Tekin RX8
savox 1268tg
Thanks!,
Dan
hey guys,
my setup is:
SCTE
tekin Pro4 4600kv
Tekin RX8
(savox 1268tg)
(spektrum receiver and transponder)
Thanks!,
Dan
my setup is:
SCTE
tekin Pro4 4600kv
Tekin RX8
(savox 1268tg)
Thanks!,
Dan
R/C Tech Elite Member
hey guys,
my setup is:
SCTE
tekin Pro4 4600kv
Tekin RX8
savox 1268tg
Thanks!,
Dan
my setup is:
SCTE
tekin Pro4 4600kv
Tekin RX8
savox 1268tg
Thanks!,
Dan
I have heard people with the SR300 that comes with the DX3S radio has been really bad at this. IF the glitchbuster doesnt work in fixing this, then the only other thing can be the bec... The RX8 IMHO is a bulletproof esc for me!
Good luck!
I see so many issues with that servo. I am not tryin to bag on any brand per se, Savox makes many great products. There is just something about that servo. Savox boosts the heck out of that one and thats why it pulls so many amps. Can try a glitch buster first, try to unplug the servo and if it still does it, may be a bad bec int eh esc or a bad receiver. Always better to make sure before buying anything else is how I feel. Always grew up on a budget, hehe.
And my bad IT'S THE 1258TG NOT THE 1268
Thanks,
Dan
It is An sr300 but it didn't come with a dx3s. Maybe I'll try the receiver from my truggy but I have used this receiver in a different car with no problems. I'll do all the double checks that you guys said before I buy anything. Does anyone have a link to which glitch buster I should buy?
Thanks,
Dan
Thanks,
Dan
Thanks,
Dan
Thanks,
Dan
The SR3100 does a much better job but doesnt always fix the issue.
hey guys,
my setup is:
SCTE
tekin Pro4 4600kv
Tekin RX8
savox 1268tg
Thanks!,
Dan
my setup is:
SCTE
tekin Pro4 4600kv
Tekin RX8
savox 1268tg
Thanks!,
Dan
I'm running the exact setup and have not had any issues. I run a glitch buster on mine and its been flawless with 60c batteries. The immediate cogging would suggest to me and indicates i would check the sensor wire and all solder joints first... The servo glitching i have seen has (in other trucks) always been under high demand
Thanks,
Dan
I'm running a 14t on a medium-large sized track, I have not needed to drop the current limit and come off around 155 after about 8 minutes... Ambient temp is in about the 90s right now.
Practiced driving around the 1/8 track at Norcal Hobbies this past Sunday and after installing my BCE chassis, Losi carbon rear tower and HA pivot balls, this truck handles EXCELLENT. Just installed my APE battery tray today and can't wait to play around with weight bias'
BTW, I've found myself turning the Expo up a little bit on my steering (Spektrum DX3C) to have a little better control at higher speeds. Has anyone else experimented with this? Seemed to work good at high speed but at lower speeds, the steering wasn't as fast as I wanted it to be (duh!). I have a cheapie Savox 0252.
Thanks,
Dan
