Like Tree9Likes
Old 03-18-2012, 10:56 AM
  #31321
theproffesor's Avatar
Trader Rating: 66 (100%+)
Originally Posted by Dano628
Even though my SCTE is fully loaded ( tuned flex , tuning kit ,HA shock bodies , torque rod , etc ) if you are not competitive with a stock one you won't be with a hopped up one . Drive it stock and get hop ups as you can the truck works great . As far as AE offering a FT kit they had to the original one needed all sorts of modifications ( I have one that I have a lot more money in then my SCTE and a stock Losi is still easier to drive fast ) enjoy your truck .
While all of that may be true, it doesnt answer the question originally posed. Does any one know if if losi (TLR) plans on releasing a true race kit.
Certain parts such as ti-turnbuckles and hardened outdrives inprove durability more than performance. Also I like getting a kit and taking all the little parts out of the bag and assembling myself vs an rtr, or arr. I like knowing how everything goes together.
theproffesor is offline
Old 03-18-2012, 11:01 AM
  #31322
BradS's Avatar
+1, I have only had my SCTE a few months and am using the stock chassis. I was able to get into the A-main at PNB with a pretty much stock SCTE. The only change I made was to use STRC alum towers, changed the Diffs to 5/5/3 and adjusted shock oil based on track. The stock chassis has worn quick, I'll probably change it soon just because it is worn out. Still trying to decide which aftermarket chassis I want.
BradS is offline
Old 03-18-2012, 11:06 AM
  #31323
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
chassis debate:
RC*PHREAK is offline
Old 03-18-2012, 11:21 AM
  #31324
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Certain parts such as ti-turnbuckles and hardened outdrives inprove durability more than performance. Also I like getting a kit and taking all the little parts out of the ag and assembling myself vs an rtr, or arr. I like knowing how everything goes together.
All them option will soon be available to purchase. Buy tgem all seperate and youll have lots of packaging to open,Dont you like checking the mail box hoping your next part you purchased is in there
BDRMBULLY is offline
Old 03-18-2012, 12:43 PM
  #31325
Default time to replace bearings. STOCK vs AVID
i have had my truck since the first few hit the shelves over a year ago. i am going to replace every single bearing in the truck. is avid better than stock?
if so....what type is most popular? just glanced at their site and you have four choices with not much explanation between the choices.
thanks.
skyler hays is offline
Old 03-18-2012, 12:52 PM
  #31326
larlev's Avatar
Originally Posted by Jake C6R
In case anyone else searched for this, the extra tinted plastic pieces are for your number on the body, the indents for screw holes are there.
And use the grommets for the steering servo.
Correct, you can use them on outside for a different look or can sandwich the body with the squarer ones and the triangles on the inside. It helps with support.
I personally use the triangle ones and leave the bigger ones in the drawer.
Not sure about tinting though....it should be just a plastic film on them.
larlev is offline
Old 03-18-2012, 12:59 PM
  #31327
larlev's Avatar
thanks.
Just go with the kit...leave options as is. Rubber is better for exposed area's like center diff for example. Can't go wrong with Avid. David is a good guy and sells quality stuff
larlev is offline
Old 03-18-2012, 01:19 PM
  #31328
cwilkinson's Avatar
+1 avid about 8 races on the avids with no issues.. Cheap also..
cwilkinson is offline
Old 03-18-2012, 01:21 PM
  #31329
05PSD's Avatar
Default Short Course Showdown Race 1
Just watched the SCTE dominate round 1 of the Scotty Ernst Short Course Showdown. Root and Castallano kicked some serious tail against what I consider the two really great AE drivers (Micheal Shoettler and Scott Brown).
05PSD is offline
Old 03-18-2012, 01:44 PM
  #31330
Default pinion gear
i just got a scte and i was going to put a 3800 4 pole castel motor
that i had it has the smaller shaft so what size pinion would i need and what
pitch thanks for any info
kbmgasaints is offline
Old 03-18-2012, 01:55 PM
  #31331
cwilkinson's Avatar
mod1 pinion 3mm shaft Someone will correct me if Im wrong but alot of people are running 14t to 16t pinion
Old 03-18-2012, 02:04 PM
  #31332
thanks. i am gonna order some tonight!
Old 03-18-2012, 02:07 PM
  #31333
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
or you can use the adapter and run 5mm mod1 pinions. I use a 14 pinion on a small outdoor track with that motor.
MOE is offline
Old 03-18-2012, 02:14 PM
  #31334
cwilkinson's Avatar
Did you find your other 2 pivot balls and put them in the shock eyes?
I should of just kept mine in the steering lol
Old 03-18-2012, 02:24 PM
  #31335
nope i tossed them.
i am bad about that. i cant stand to be a pack rat. i will cough up $7 and get some new shock rod ends. they need replacing anyway.
