RC10B4.1 FT/WC
Old 04-20-2012 | 02:22 PM
  #13906
brent701's Avatar
Originally Posted by bilster44
Without SERIOUS grinding modifications to the rear arms and hubs, the T4 chassis is ILLEGAL in the buggy class.
What would you have to grind?
It should all bolt right up.
brent701 is offline
Old 04-20-2012 | 02:42 PM
  #13907
Jake S's Avatar
i believe he means the buggy wheel base is too long with a full t4 chassis to meat roar rules.
club racing, all good
Jake S is offline
Old 04-20-2012 | 03:38 PM
  #13908
idrummerboy13's Avatar
Originally Posted by kdub
To answer a question from last page, the springs come with shrink tubing to indicate color.
Our springs have thicker wire and more coils than the Losi kit springs, so they feel a bit different on the track. I think the thicker wire and more coils soaks up the small bumps better and makes the car feel more connected to the track.
Kurt
gatt a say u guys are doing lots of good things lately....Thinking about what my avid order is ganna b...idk if I want the steering rack but ik I want springs for my buggy and 4wd...bearings would be really nice also....stock work well but I find they shatter in the rear hubs even with me cleaning em out and lubing them..
also those losi bb springs made my car really unpredictable at times and I made more mistakes...stock springs and k dk yellow fronts is what I am running and I love the feel. What springs do u think I should start with? Med bite-high indoor smooth clay....Traction is good and not to many large jumps corner speed is what I like and on power turn.
idrummerboy13 is offline
Old 04-20-2012 | 04:34 PM
  #13909
brent701's Avatar
brent701 is offline
Old 04-20-2012 | 05:17 PM
  #13910
kdub's Avatar
I posted my base spring setups a while back. I run red-red but the yellow-yellow has a good balance too but is softer. I would try that on low grip or with the shorty pack. I think the bearings, 12mm springs, and the steering bellcranks are a must-have for serious racers.
We also have hex adapters and we'll have hex wheels within a couple weeks.
kdub is offline
Old 04-20-2012 | 06:05 PM
  #13911
Buckaroo's Avatar
WRONG. Check your resources
ROAR max for buggy is 292mm, AE website shows the T4 wheelbase is 288mm and the B4Worlds is listed as 281mm (with a standard B4.1 being 273mm). A buggy on a T4 chassis would make a buggy +15mm over a standard chassis and +7mm over a Worlds spec and still have 4mm in overall wheelbase to spare. It's been done time and again, and IS legal.
All still well within legal based on ROAR regulations to use a T4 chassis on a buggy, as long as you're using trailing axles. Inline axles will make it 1 or 2mm over max, depending on how you set up the rear wheelbase spacers and toe.
It does.
Buckaroo is offline
Old 04-20-2012 | 06:14 PM
  #13912
Kurt04's Avatar
ROAR max for buggy is 292mm, AE website shows the T4 wheelbase is 288mm and the B4Worlds is listed as 281mm (with a standard B4.1 being 273mm). A buggy on a T4 chassis would make a buggy +15mm over a standard chassis(4mm to spare) and +7mm over a Worlds spec(11mm to spare).
It does.
And they already have a body for it, the J82.
Kurt04 is offline
Old 04-20-2012 | 06:15 PM
  #13913
Buckaroo's Avatar
Avid makes one as well.
Buckaroo is offline
Old 04-20-2012 | 06:18 PM
  #13914
DirtRacer68's Avatar
Where is everyone running the mod buggy class in Central Pa, for the summer? I know Pitstop races on Fridays, is there any other tracks?
DirtRacer68 is offline
Old 04-20-2012 | 07:42 PM
  #13915
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
The inline spindles do not affect wheelbase whatsoever if used properly.
T-BirdJunkie is offline
Old 04-20-2012 | 08:27 PM
  #13916
dekar058's Avatar
The Compound is running all year long. We race on Sundays. 2wd Buggy is a very competitive class at The Compound. Swing up some time you won't be disapointed.
Derek
dekar058 is offline
Old 04-21-2012 | 12:12 AM
  #13917
Wild Cherry's Avatar
Tech Legend
It will fit in the Box...
I believe , but not for sure....
a B4 won Stk Nats with.....
Again not sure, think the longer 8mm chassis development all began from that event occurring .
OYeah .....
ps
Pete , just do it , or make a 10 mm or 11mm chassis...
Wild Cherry is offline
Old 04-21-2012 | 12:35 AM
  #13918
Guest
OYeah .....
JUST WHAT EVERY
ps MANS NEEDS, JUST A LITTLE LONGER,,,,,, CHASSIS!!!!!
JUST WHAT EVERY MANS NEEDS, JUST A LITTLE LONGER,,,,,, CHASSIS!!!!!
LOSIRACER77 is offline
Old 04-21-2012 | 12:41 AM
  #13919
IRM616's Avatar
What tires do u recommend for high bite track...clay. I use run gold barcodes now looking for something similar but not jconcept
IRM616 is offline
Old 04-21-2012 | 01:07 AM
  #13920
Guest
THERE IS A hotbodies tire that performs great on a indoor clay track!!!!!!! but they look like aka re bars, they come in red compound( soft--super soft) , i have seen these tires run, look in to it, u will be happy!!!!
#67774 - HB BEAMS TIRE (2pcs/Red/Rear/ 1/10 Buggy) #67778 - HB FULLSLOT TIRE (2pcs/Red/2wd Front/ 1/10 Buggy)
#67775 - HB FULLSLOT TIRE (2pcs/Red/4wd Front/ 1/10 Buggy)
here they are!!!!!!!!!!!!!! different and they work!!!!!!!
