RC10B4.1 FT/WC
Old 06-01-2012 | 09:13 PM
  #15406
Originally Posted by 20 SMOKE
is anyone using the red or purple avid spring
I am running red front and red rear. 32.5 #2 pistons
goin2drt is offline
Old 06-01-2012 | 10:24 PM
  #15407
Originally Posted by ilanstylz
Thanks Asharus I will try out that gearing........
Also what is the mod I remember reading a little bit about on shaving the U-brace? What does it help and where do I shave it, anyone have pics? Thanks
Hope this helps. Shave the U-brace where the inner turnbuckle holes are, flush with the brace. I used a bench grinder to get it close then a nail file to finnish. Careful not to get the tranny mounts!! I did this to a mildly upgraded B4.1RTR, made the car more stable in the turns and easier for me to drive it, this one was all over the place no matter what I did to it!. I have only tried this setup on clay so not sure if it's a plus on dirt yet? Hopefully I'll find out this weekend.
Attached Thumbnails RC10B4.1 FT/WC-100_1763.jpg
Tc3junky is offline
Old 06-02-2012 | 02:41 AM
  #15408
gamedog1966's Avatar
Hey guys, what is a good setup for indoor smooth clay with high bite that is easy to drive and not too aggressive? I have what the fast guys at my track run but the car is way too aggressive for me and they dnt run there enough during the week to help me seriously just only on race days and by then it is show time and I'm running a car that is kinda hard to drive whne I'm really trying to be consitenly fast
gamedog1966 is offline
Old 06-02-2012 | 02:42 AM
  #15409
Another thin is that is have a crap load of play in my rear hub carriers I think that is vey sloppy, I just recently rebuilt my front and rear end of my buggy and still sloppy
Old 06-02-2012 | 04:25 AM
  #15410
20 SMOKE's Avatar
anyone have losi springs they want to sell,dont want to drop the $ on avid just yet unless i can get then single
20 SMOKE is offline
Old 06-02-2012 | 06:12 AM
  #15411
F18engineguy's Avatar
I do...PM sent
F18engineguy is offline
Old 06-02-2012 | 10:15 AM
  #15412
socalrcer's Avatar
Is the rear end coming around too fast when you are off throttle? If so taking away grip from the front will help. Use the dual rate on your radio to tone down the steering. Stiffer front springs makes your steering quick when going slow but will slow down your weight transfer to the front when you are coming in to turns faster, giving you a little push, but this should take away some of the rear end swap. Going with softer springs all around in general should slow the whole car down if you are looking to calm it down in all sections. Also you may try running at 25mm ride height instead of 24mm to get more grip and settle the car more in bumpy sections.
socalrcer is offline
Old 06-02-2012 | 11:25 AM
  #15413
I've made a few changes to the car like go from losi silver fronts to losi orange and moving the front shock tower pos from iner to middle and lowerd my ride height from 24 to 23 due to carrying more speed thru the sweeper and trying to minimize traction roll possibilities even with old slicks and firm foams in em. I've turned my steering expo to
-15 and I cnt really tell that much of a diff with the expo tho. Idk mayb it is just transitioning from sc to buggy cause I drive my sc well and inconsistent withh my buggy. The only time I drive the buggy well is if I drive slow and I know slow is fast but at my track slow finishes at best in the back our fast guy are fast as hell if ya know what I mean. I take they advice and it helps but it sucks when u drive clean and smooth but not confident enough to drive your car to the cars capability. I drive my sc like a bat outta hell n cnt do tha with my buggy. I wnt the buggy to b easier to drive, ya know
Old 06-02-2012 | 11:57 AM
  #15414
19_mustang_96's Avatar
anyone got a good setup for a loamy track?
19_mustang_96 is offline
Old 06-02-2012 | 02:23 PM
  #15415
shadowracer24's Avatar
I ran mine with the red avids both front and rear on the carpet track last night and it was hooked up very well. I do feel that they would be to stiff for dirt racing and use the yellow fronts and white rears and that seems to work best for me.
shadowracer24 is offline
Old 06-02-2012 | 05:43 PM
  #15416
AErckidd's Avatar
How often do you guys change your shock oil? Taking into consideration big races, practices and just club races.
AErckidd is offline
Old 06-02-2012 | 06:05 PM
  #15417
JakeC351's Avatar
I change it after everyday I drive my car.
JakeC351 is offline
Old 06-02-2012 | 09:07 PM
  #15418
idrummerboy13's Avatar
that was always a must for me....
id have to drive this thing when there are a.e bb on it. I hope the b5 matches the other kits in all aspects...
idrummerboy13 is offline
Old 06-02-2012 | 10:46 PM
  #15419
This weekend was my first weekend racing my B4.1 Worlds. I have a couple issues that I'm sure are easy fixes.
Setup - Tekin RS Pro, Tekin 13.5, Avid Springs (Red) with not much preload at all, Savox 1258, Avid Carbon Fiber Rear Hub Tower (middle/bottom location), Avid Steering rack, Shocks 30 front/25 rear
Track - Hard pack with some dust, parts rough and parts smooth
Problem 1. I'm having lots of push even at slower speeds. I'm having to use my brakes to swing the back end around on slower turns. Is this just normal for these buggies? I've only ever driven 4x4 Short Course.
Problem 2. 2 out of the 4 races my servo arm connecting ball cup popped off. Any better options as far as parts go? A pretty hard chassis slap caused the first one I believe which could be part of the issue.
Loved racing this buggy and can't wait to figure out my issues and go kick butt!
jdrake19 is offline
Old 06-02-2012 | 11:56 PM
  #15420
I'm sure you'll hear more from smarter racers than I but your issues sound the same as mine first weekend out. I yanked one of the washers out from under the front ballstuds on the tower side. Also, I added some weight up front. 7 grams under the front brace and 7 on each side of the servo
Leadfinger2011 is offline
