RC10B4.1 FT/WC
#7906
[QUOTE=-WHEELMAN-;9971231]Your Tekin motor will pull 13.5 D3 motors all day long you do not have it geared correctly! Add two teeth to the pinion at a time until your motor is between 150 and 170 after 7 minutes of run time. It will be amazing to you how much faster it is geared correctly!
That's what I figured. I am geared 22/81 now and it hauls. I tried to put a 27 in with the 81 and it doesn't fit. I don't need any more top end just looking for more low end grunt. I don't use any ESC timing or boost, just 12* on the can. Would some boost or timing help any? I am just used to my 4pole castles having serious low end, but love to sensored motor.
#7908
Gear up until your motor temps are around 150 after your main. You can move the motor back and forth by using different spurs but keep the same pinion/spur ratio. That truck is going to fly. You are going to need a wheelie bar!
#7910
#7911
whats a good starting point (pinion/spur) for a boosted trinity d3 17.5 using a tekin rspro esc? i'm new to advance timing and usually run a 7.5 in mod buggy,but i know i dont have a chance against the best in the world at next months jconcepts clash so stock buggy will haft to do
anyhelp would be awesome
#7912
#7913
#7914
#7915
Drag link from servo to steering arm pivot calls for approx 1/16th in manual, for full lock to lock 2mm is needed (team guys are using a blue spacer, I had 2mm spacer)
Bolts for transmission do need thread lock AND double check after first few runs. When you assemble it, do not crank down just snug, tighten after tranny is run a bit.
AE springs are icky, especially green rears. I have converted to losi big bore springs. Losi orange in front, yellows or pink in rear. Used traxxas spring holders up top to retain, used losi 22 spring holders on bottom. Very smooth, could tell they were better right away with no other changes.
Do yourself a favor and get what ever setup works for your track, before the build, all anti-squat/shock pistons/toe blocks come in the kit to set it up from the get go. Easy build, great fit and finish, great design.
I picked up all the carbon parts, +8mm chassis. Car drives like a champ, great fwd traction and steering, especially on the gas in sweepers. You can drive it in and out of corners quite well, my biggest complaint of my 22.
