RC10B4.1 FT/WC
#6406
Alright here's the best way I can help with the arm situation.
Attached is a picture of the current selection of arms.
The top one is a carbon arm. The stiffest arm, it is signified by one swaybar mount ball (B4 swaybar, not B44), and a very light color.
The middle one is a B44/B44.1 arm (the materiel did not change between vehicles). This arm has more flex than a carbon arm but less than a B4.1 plastic arm. Notable differences are, glossy color as well as a cut out on the webbing of the rear hub along. If you look very very closely you can see rectangular indentations on the top of the arm from the mold.
The bottom one is a B4.1 plastic arm, the softest arm made. A dark dull color as well as no cut on the webbing and two swaybar mounts are the best way to recognize this arm. Again if you look very closely you can see circular (as opposed to rectangular) indentations from the mold.
The original B4 plastic arm (older materiel) isn't produced any more but can still be found at some hobby shops. It has one swaybar mount and looks exactly like the carbon arm, just a darker color.
In order to be certain we have the latest T4.1 plastic and carbon mold, was hoping he can clear it up for us. Thx!
#6407
Your market for 8mm B4.1s just dried up!
I want a T4.1 +4 I think. Maybe a +2. Gotta figure out how long the 22T is and go from there.
#6408
#6409
They sell a 4mm and a 12mm as well. The 12mm matches the length of the TLR22.
That said, I'm wondering how much added weight the new AE +8mm will weigh? Anyone see anything out there about its weight?
#6411
#6412
#6413
#6415
From: Norwood, OH...and CCRCR and The OhioRCFactory
As Wild Cherry recommended...repeat the bleed process once more. Do all that you stated and work the shaft up and down about 10-15 times and then compress the shaft in while backing the bleed screw off. The excess oil will bleed out, replace screw and you should be done.
#6416
#6417
#6418
I'm sorry, this. http://www.amainhobbies.com/product_...Ballast-Weight How many people use this?
#6419
#6420
