RC10B4.1 FT/WC
With running 17.5 Blinky I have taken all the weight out of the car. I want to set it up as light as possible. Power to weight ratio is the key for me. If I can get the thing to turn and hook up with springs, shock oil, diff settings, etc... than it should be good to go. I think it is crazy adding a ton of weight to an under powered vehicle. Just my two cents...
too add
Just from what I have experience
BB springs are actually softer at first , explaining that extra grip & plush ride they bring...
A few have said the improved performance is due to the fact they do not rub the shock body less .
Not so...
and
now you now know why ...
Not so...
and
Given all the above though. I am going to go ahead and try them myself.
Doesnt a progressive spring have dual rates of compression and this would be stated by the mfg if they where? Going from a softer spring rate to there higher rate of compression as its compressed? For me I nvr bothered to try them because I always was under the assumption that they where both linear spring rates and that there shouldnt be any difference between the two.
Learned most about this topic by testing with my teammates @Trcr..
I will be honest , never really looked at those charts ..
We just put um on and check how fast we go with the
track computer ...
Usually 4 or 5 us testing , sometimes late into the night .....
I run this pretty much exact except for the weight in the front triangles,I'm running a shorty lipo and once I added the weight in front of the servo my buggy became money,I will try out the rear whites and orange fronts to go with my yellow/red combo
Geo my biggest problem with the BB was that ultimately we are all on different springs. I can't get KY springs around here and not sure I would spend the money for them anyway. So I'm forced to use the Losi. I can throw orange / yellow combo on and feel safe no matter where I go but I will constantly second guess myself thinking oh I can go a lil quicker with silver or white.
I end up over thinking the spring choice. When the AE stuff is finally out, that should resolve the problem and I'll go back to them.
I've never heard of anyone ever saying that, and I have measured active coil height spacing and they do not change (indicating that they are linear). During operation non of the BB coils coil bind either.
Suspended
Hi
I'm new to off road and just got a b4.1, I ran it indoors for the 1st time tonight, the car is grate and ran well apart from 1 thing, when I was going over jumps the back end was trying to over take the front and the car was trying to flip. Any setup help any one could offer would be grate.
Got it from a Ae factory team driver ...
If a manufacturers springs were progressive wouldn't they advertise them as such....? They could be hand wound by little green men contracted from Mars for all I care as long as they work.
