RC10B4.1 FT/WC
Old 03-07-2012 | 10:52 PM
  #12511
Suspended
Originally Posted by racer1812
Heh, Cherry will never tell us that
All you have to do is see who on the team races in Tacoma
PFKAOG is offline
Old 03-07-2012 | 10:57 PM
  #12512
vr6cj's Avatar
If a manufacturers springs were progressive wouldn't they advertise them as such....? They could be hand wound by little green men contracted from Mars for all I care as long as they work.
I guess thats what I was getting at eariler.
vr6cj is offline
Old 03-07-2012 | 11:05 PM
  #12513
carver gt's Avatar
Can't seem to find Losi BB silver ft Losi BB white rears anywhere. Anyone know?
carver gt is offline
Old 03-07-2012 | 11:17 PM
  #12514
CraigMBA's Avatar
Originally Posted by vr6cj
Doesnt a progressive spring have dual rates of compression and this would be stated by the mfg if they where?
You're right, George is wrong. Nothing new there.
Going from a softer spring rate to there higher rate of compression as its compressed? For me I nvr bothered to try them because I always was under the assumption that they where both linear spring rates and that there shouldnt be any difference between the two.
Correct again, Wild Cherry is just spewing nonsense. As usual.
Actually, that's not true. The fact the spring is hitting the side of the shock is precisely the problem, not because it was hitting, but because it is deflecting off to one side.
Given all the above though. I am going to go ahead and try them myself.
The reason users are having problems is the rates on the Losi springs aren't the same as the AE springs. A AE green rear is a 1.9, a yellow TLR 22 spring is rated at a 2.0, and when I rated them, the TLR was substantially softer than the AE. YMMV.
George is going to say something personal and inflamitory in response to what I posted. He won't have any data to back up what he says, but that's standard. His response is always:
Got it from a Ae factory team driver ...
And my response is either you were lied to or he is wrong, because your answer is lacking in depth and truth. But we've been here before...
CraigMBA is offline
  #12515
Well, four of them hail from TRCR... Anyways, the kyosho springs are feeling excellent. I defiantly noticed that they where initially softer and then sort of simulate "pack". Losi springs work great too, either way cant go wrong...
SmItH_aLeX is offline
Old 03-07-2012 | 11:31 PM
  #12516
CraigMBA's Avatar
The guy who works at AE and is developing the big bore stuff posts here on RCTech. I can't remember his username, and I need to go to bed. Anyone know what it is? He posted on what the advantages of the big bore springs are, the problems with the smaller springs, and why the small shocks may have an advantage over the big shocks (both using the big springs).
He didn't say any of the things George did. And he works there and has his mess together.
If somebody would please get me his username, I'll do the search and repost what he wrote on the topic a couple of months ago.
CraigMBA is offline
Old 03-07-2012 | 11:43 PM
  #12517
el Bourlando's Avatar
. Is it Tim Tunnerman?
el Bourlando is offline
Old 03-07-2012 | 11:49 PM
  #12518
CraigMBA's Avatar
Yep, thanks. Here it is:
Originally Posted by patiofurniture
Aside from the springs rubbing there are other benefits to the BB springs. Since they are a larger diameter, for a similar spring rate the willingness for the spring to buckle reduces substantially, and therefor decreases any side loading that would be imparted onto the shock (also causes the rubbing). This side loading increases shock shaft drag and reduces the amount of force being transferred to the tire. A lower force (downward), especially when cornering decreases tire grip. Both of the Ryans feel that our standard shock creates more side-bite than a BB, at the expense of the car not landing big jumps as well. I personally don't really think BB's are better, and we have been able to prove that they are magical (significantly faster) in any sense but there are some small advantages. I think people in general just think they need them....but we are working on our BB shocks and they will definitely be THE BEST!
None of that garbage Wild Cherry was spewing, but there you go. Facts have a liberal bias.
CraigMBA is offline
Old 03-08-2012 | 12:22 AM
  #12519
LOSI123's Avatar
Can anyone tell me what spur gear/gears come with the worlds kit
LOSI123 is offline
Old 03-08-2012 | 03:10 AM
  #12520
elex300's Avatar
75 and 81.
elex300 is offline
Old 03-08-2012 | 05:01 AM
  #12521
elex300's Avatar
Heading to the lhs shortly and want to try the Losi BB spring what collars and cups do i need to buy? Also which colors are used most. On My 22 I go between Wht and yellow rears and red and orange fronts. Is it the same with the B4.1 +8?
elex300 is offline
Old 03-08-2012 | 05:08 AM
  #12522
storm800's Avatar
I would get exactly the springs you stated. We are currently running the Chad Due setup minus the pistons on my sons car and it is hooked. Red front-white rear.
storm800 is offline
Old 03-08-2012 | 05:52 AM
  #12523
elex300's Avatar
Which collars and cups do I need to buy so they will fit?
elex300 is offline
Old 03-08-2012 | 06:26 AM
  #12524
Response of the decade!
adam lancia is offline
Old 03-08-2012 | 07:57 AM
  #12525
Wild Cherry's Avatar
Tech Legend
O-look !
someone else who knows why we use the BB springs....
Guys , I could respond to the the one guy who only wish's to bash someone for trying to help you out with understanding why the BB springs perform as they do ...
please note
No name calling or negative remarks from me...
I won't even try as it just ruins our thread , hope you all can appreciate...
Someone also asked which Team member told me this info &
because Racer , a RcTech mod said I never say where I got the info ....
We were doing as I said testing at the time , so one of us text Cody , or I believe it was Coach himself .
This is where we got the Info about the progressive nature of BB springs ...This happen months ago ...
Wild Cherry is offline
