RC10B4.1 FT/WC
Welcome to offroad! Sounds like you might be either tapping the brakes in air or you might have pretty strong drag brake set. With off road cars you can adjust the attitude of the car in the air with the throttle. More throttle brings the nose up and less throttle or brakes brings the nose down. Hope that helps.
Cheers
Its possible that it could be the wing but that seems less likely than some of the other things that typically stick your rear end over the front end. Usually its deceleration of the drive train. I suppose it could be light oil and too strong of a spring in the rear. What is your setup? Also, what does the jump look like?
I go faster with BB springs, make fewer mistakes with um too ....
Can tell you all why .....
better control with roll in the turns ( less hook , less square)
more traction & a plush ride or smoother ride
I still dont understand one thing. If the springs rates are the same(or slightly different/if any) then how is this?
For guys running 17.5,
how much weight spread around are you using. The guy at my lhs told me I had too much weight in mine. I just want mine to be planted and have lots of steering.
I have 5 g in each triangle and 20 g in front of servo and 14 g below rear shock tower.
I bought the ballast weight and may replace 14g on shock tower.
A Ae spring is very linear, as the spring is compressed the rate stays the same ....
The other BB springs we have been using are more progressive and their rate goes up as the spring is compressed .
Hi
I'm new to off road and just got a b4.1, I ran it indoors for the 1st time tonight, the car is grate and ran well apart from 1 thing, when I was going over jumps the back end was trying to over take the front and the car was trying to flip. Any setup help any one could offer would be grate.
Ok, so I get that. I understand the difference in progressive and linear. I saw that spring rate chart posted a few pages back and it didnt state what springs where progressive or linear...just the rates. I assumed the BB listed on it where Linear. So your saying the BB springs are a progressive spring rate. IE Losi 22 BB springs everyone is using for instance?
what will match what I have on now? brown front with green rear?
For 8m chassis
1/2oz in ft of servo
1/4oz in the ft triangles by servo
1/4oz in rear triangles
Ae ballast weight on rear arm mount by transmission, can go more , as much as 21 g for max steering.
too add
Just from what I have experience
BB springs are actually softer at first , explaining that extra grip & plush ride they bring...
A few have said the improved performance is due to the fact they do not rub the shock body less .
Not so...
and
now you now know why ...
