RC10B4.1 FT/WC
Old 03-10-2012 | 07:04 AM
  #12631
njnewc's Avatar
Wile E Coyote figured it out...
Attached Thumbnails RC10B4.1 FT/WC-wile-e-coyote.jpg
njnewc is offline
Old 03-10-2012 | 07:38 AM
  #12632
916bdogg's Avatar
Hey Tards there just springs for toy cars, Move on ,like the Tech Said ..
916bdogg is offline
Old 03-10-2012 | 07:44 AM
  #12633
the big rc's Avatar
Originally Posted by mxracer458
so are the ghea pistons worth 22 bucks?did you really notice any difference?
Huge difference. Made mine like butter.
the big rc is offline
Old 03-10-2012 | 09:11 AM
  #12634
jf+'s Avatar
jf+
Ouch. Been a rough few weeks for my buggy.
Broke the chassis, steering rack, top plate, diff case (both sides!), rear tower, two rear arms, and a wheel.. Yes, a wheel. (?!)
Bent two dogbones and lost another, and two turnbuckles..
Had to replace a servo horn, motor guard, front axles..
Kind of discouraging, learning this skill.. maybe I need to start running on a Nerf track. Seems like as soon as I get everything in order, I break again. Getting expensive!
jf+ is offline
Old 03-10-2012 | 09:35 AM
  #12635
What exactly are you doing with the buggy? I can't say that I've broken that much stuff in the entire time I've had my first B4 (purchased when they originally came out). I'm not trying to be a dick, just trying to figure out a possible solution.
adam lancia is offline
Old 03-10-2012 | 09:36 AM
  #12636
Teambcw's Avatar
Holy smokes!!! did you run it over with your real car?
Teambcw is offline
Old 03-10-2012 | 12:23 PM
  #12637
racer1812's Avatar
Super Moderator
Originally Posted by harold56
Wow DaveW you have repeatedly shown you have no clue as to how a coil spring works. And timmahh you are completely correct.
no timmahh is not correct, If you have (2) 2lb/in springs and stack them each spring will only move 1/2 an inch with the same 2lb load. It will now take 4lbs for each spring to move the rated one inch.
racer1812 is offline
Old 03-10-2012 | 12:51 PM
  #12638
Matt Trimmings's Avatar
+ YouTube Video
Matt Trimmings is offline
Old 03-10-2012 | 02:21 PM
  #12639
LOSI123's Avatar
hey guys does the worlds kit come with the junk inserts or molded or closed cell?
LOSI123 is offline
Old 03-10-2012 | 02:31 PM
  #12640
harold56's Avatar
Try it. Take two springs attach them on top of each other and put a controlled amount of weight on them and measure how far the weight falls. Now take each spring individually and do the same thing. guarantied you will see a higher spring rate with the individual springs. if you don't want to do that go to college and get a mechanical engineering degree, as many on this board have done.
harold56 is offline
Old 03-10-2012 | 02:40 PM
  #12641
SoccerSting's Avatar
Just a thought. Has anyone thought of using tubes instead of foams? I know you couldn't find any that size but maybe a company has tried them and they haven't work out? They would never wear out like foams and you can adjust the firmness of the tire without having to take the tire off and putting different foams in.
SoccerSting is offline
Old 03-10-2012 | 03:23 PM
  #12642
socalrcer's Avatar
Are you using the tapered or flat?
socalrcer is offline
Old 03-10-2012 | 03:24 PM
  #12643
flippz's Avatar
http://www.rctech.net/forum/electric...l#post10449078
again a reminder, just a friendly reminder
flippz is offline
Old 03-10-2012 | 05:00 PM
  #12644
Hard Drive's Avatar
Looking for a good gear ratio to start with to run stock class. I'am running the Ballistic17.5 in the b4.1.
Hard Drive is offline
Old 03-10-2012 | 05:25 PM
  #12645
racer_guy's Avatar
so i got the worlds kit. either i didnt get the paper or i trashed it but there are 2 things...long thin foam (im guessing for under the battery strap?) and where the ballast weight goes. cuz it says install weight before transmission. any help guys? thanks in advance
racer_guy is offline
