RC10B4.1 FT/WC
Old 03-03-2012 | 10:39 PM
  #12361
Default Aka foam
Has anyone tried a set of aka's front close cell foam inserts? I want to try a set in some Bar Codes
Jaymo13 is offline
Old 03-03-2012 | 10:49 PM
  #12362
OptimumRC's Avatar
Originally Posted by NYC Diesel
If the MIP diff was the correct one then I must have an issue with my dog bones. My car didn't come with CVD's just the crappy black dog bones. So if I get the FT CVD's I will no longer have an issue ? What about the MIP CVD's ? They seem to be better stocked locally.
If you are using the bones, did you also make sure to put an o-ring on each side of the diff and inside the stub axles?
If you didn't do this (which is common) then your dogbones will have too much lateral play and will pop out.
OptimumRC is offline
Old 03-04-2012 | 02:01 AM
  #12363
Won my first race today with my b4
was pretty proud but couldnt of done it with out the kindness of the person who let me borrow there radiopost controller because my spektrum took a dump and the spring popped out on the wheel. After using that radio post i may have to look into one when i get the money
chancejeff is offline
Old 03-04-2012 | 02:24 AM
  #12364
No I didn't, I didn't even no they were in there. Could I just pull the orings out of my gear diff ? I'm going to try to upgrade to CVD"s asap.
Another interesting thing I found is that both the diff kits I bought now have the same bearing size(5/32 x 5/16). Maybe AE corrected the problem and changed it to the correct bearing?
NYC Diesel is offline
Old 03-04-2012 | 04:56 AM
  #12365
Matt Trimmings's Avatar
The correct oring is a shock oring, not the ones from your gear diff. The internal bearings are the same. The outdrive bearing in the tranny case is different.
Matt Trimmings is offline
Old 03-04-2012 | 05:14 AM
  #12366
B.A. Racer's Avatar
Try a set..I tried closed cell for the front and did not like it at all
B.A. Racer is offline
Old 03-04-2012 | 05:32 AM
  #12367
fastharryDOTcom's Avatar
Originally Posted by 20 SMOKE
that's the weight,you may need different toe blocks they need to have a cut in the back of it to capture the weight in
Ya know, Like I said, I finally started to build this thing...and after 15 minutes I made an executive decision..
I'm selling the b4 FT and gonna buy a new buggy. I'm not going with old technology.
Gonna look at the Losi...but will probably get the Worlds car as that is what all my fellow racers are using and to be honest, after 15 years of racing, I'm getting tired of always bucking the trend, LOL...
I have it up on EBAY as we speak.
fastharryDOTcom is offline
Old 03-04-2012 | 06:07 AM
  #12368
PHIL700XCSP's Avatar
I am currently using a set and I like them. They took a little bit to break in. Not sure on the longevity as I've had them in for about 5 races.
PHIL700XCSP is offline
Old 03-04-2012 | 09:26 AM
  #12369
How did they make the car feel when you first put them on, compared to the stock inserts?
Jaymo13 is offline
Old 03-04-2012 | 09:33 AM
  #12370
Default Kyosho & Losi springs
Does anyone know what kyosho springs are the closest in spring rate to the losi orange and yellow springs?
What kyosho spring are you guys running?
Jaymo13 is offline
Old 03-04-2012 | 09:51 AM
  #12371
There is a big bore spring chart in here somewhere. As far what people are running...white/pink front and white/gold rear.
Old 03-04-2012 | 10:00 AM
  #12372
JakeC351's Avatar
I'm running koyosho whites in front and golds in the rear. And love them used to run Losi orange in the front and yellows in the rear and they felt really good but koyoshos even feel better!
JakeC351 is offline
Old 03-04-2012 | 10:03 AM
  #12373
nismomike's Avatar
Here's a link to the chart. My photobucket album is not loading so.....
http://imageshack.us/photo/my-images...ringchart.jpg/
Oh there it is!
nismomike is offline
Old 03-04-2012 | 10:08 AM
  #12374
nismomike's Avatar
Awe! Those are the standard Kyosho's! Well, there it is for the guys wondering about the losi vs AE conversion.
Old 03-04-2012 | 10:14 AM
  #12375
Could somebody help me with a setup for tight high bite clay(run slicks for tires) Running the stock worlds setup now and it is pushing incredibly bad. I have the battery all way forward and no ballast in the rear. Also what should these weigh rtr?
turtletrax is offline
