RC10B4.1 FT/WC
Old 08-08-2011 | 12:30 PM
  #4861
gregm's Avatar
Originally Posted by swoll_929
speaking of wings... Are there any molded wings for b4.1? Ive seen like carbon or composite wings for other buggies (not sure if they were nitro???)
What about front wings, any difference?
The only molded wing I have seen was offered by Academy and it was pretty durable and cheap. It needed to be trimmed up quite a bit to make it fit and I used it for quite a while. I am not sure if you can get them any more but the part number from Stormer is acdsb007
gregm is offline
Old 08-08-2011 | 12:44 PM
  #4862
Thanks but they say out of stock, didnt have a picture or anything, i think i'll just go JC punisher w/ 6.5" wing seems to be the way to go.
Still not sure about front wings though.
Also thinking the before suggested goosebump rears will be a good choice.
Anyone know about "rips" for the front on dry hard pot holed dusty track? Or should i just go w/ the stock style?( my stocks are still in very good condition)
swoll_929 is offline
Old 08-08-2011 | 12:46 PM
  #4863
Jmuck69's Avatar
Rips or Groovys
Jmuck69 is offline
Old 08-08-2011 | 12:51 PM
  #4864
tecniquin2001's Avatar
Yup, I would also recommend JC Groovys for outdoor racing....
tecniquin2001 is offline
Old 08-08-2011 | 01:42 PM
  #4865
becdino's Avatar
opps
becdino is offline
Old 08-08-2011 | 01:44 PM
  #4866
becdino's Avatar
This truck is not for me
becdino is offline
Old 08-08-2011 | 03:25 PM
  #4867
Robert Drew's Avatar
Exclamation
Does anyone have the part numbers for the Kyosho dark yellow front springs, and the Kyosho black, dark yellow, and blue rear springs? Thanks.
Robert Drew is offline
Old 08-08-2011 | 04:19 PM
  #4868
Matt Trimmings's Avatar
Front Dk Yellow: KYOW5181-60
Black: KYOW5183-03
Dark Yellow: KYOW5183-60
As for the blue's, there is the cobalt blue: KYOW5183-72
And the Dk Blue's as well: KYOW5183-68
Matt Trimmings is offline
Old 08-08-2011 | 06:27 PM
  #4869
idrummerboy13's Avatar
ok guys guys i need some help. I run the car for about 5 min and after that on jumps it starts to cog and it really throws me off. I changed the diff, tranny is mint, cvds dont bind. changed pinion and spur. I used 3 different batteries and a new sensor cable along with a moter. The one thing i didnt change is the speedo. I am ganna throw this lrp in the garbage if its the speedo.
HElp!!
idrummerboy13 is offline
Old 08-08-2011 | 06:32 PM
  #4870
If it really is cogging you might want to try the speedo or motor thread.
Just a warning I fought all last year with a similar situation and it was a jr servo feeding back into the receiver... so don't rule that out either.
gguertin145 is offline
Old 08-08-2011 | 06:42 PM
  #4871
Eli's Avatar
Eli
HElp!!
Battery connections good?
Eli is offline
Old 08-08-2011 | 06:48 PM
  #4872
skrichter's Avatar
Default Bling
Looking to add some bling to my B4.1, with a screw kit, that doesn't cost a $100 bones like Lunsford titanium kit which the factory boys ran at Worlds.
Thinking maybe stainless would be a cheaper option. Anyone know what stainless weighs in at vs. the normal screws?
Any suggestions are welcomed. Thx!
skrichter is offline
Old 08-08-2011 | 07:04 PM
  #4873
jph
Default setup help
Under-steer on throttle, over-steer on brake. I know some is normal, but how much is too much? Accelerating, the car won't turn, if I use the brakes in a turn, it hooks and does a 180. I thought the diff was too tight, I loosened it till it slips- same problem. It seems like the weight is shifting too much. How do I fix that?
Or is it just me?
I'm using Cavalieri's indoor clay setup at the Outback Raceway at Amain.
Thanks.
jph is offline
Old 08-08-2011 | 07:09 PM
  #4874
Registered User
HElp!!
Please clarify what you mean by Cogging
Ryno B4.1 is offline
Old 08-08-2011 | 07:17 PM
  #4875
Jmuck69's Avatar
I believe stainless is heavier. I would look at blue aluminum or any other color to use. Use on nonstress areas like tranny case and shock cap bleed screws. I personally like the lundsford Ti screws.
Jmuck69 is offline
