RC10B4.1 FT/WC
#6361
God Speed
how bout this
#6363
#6364
Leaking FT shock caps?
My FT shocks on my brand 4.1 are leaking from the caps. I thought i read about others having this problem early in the thread but can't find it now.
Am i possibly over tightening them? I put a bit of slime on the o-rings to keep them in place while i put on the cap.
#6366
When I build the shocks the shafts suck up to the body. How do I prevent that?
It seems like I should let a little air IN so there isn't a vacuum pulling the shafts in. Currently the chassis will slap after the jumps. I noticed the other cars were absorbing the bumps really well. Mine wasn't.
#6367
Super Moderator
Trader Rating: 31 (100%+)
I don't do this ^^ but after I cycle my shocks a few times the oil/air emulsifies and the shafts no longer pull back in.
#6368
I have been bleeding the shock as the instruction say , then I push the shaft up & down a few times and repeat the bleed process once more ...
#6369
Which rear hubs seem to work well at most tracks..0*; .5*; 1*; 1.5*
#6370
0 degree hub , 3 degree toe block
#6372
If you try switching to the 2.5 toe block , the car rotation* will be faster , more steering, less traction or grip .
Switch to the .5 hub and the cars rotation will
slow down, less steering, more traction .
Yes, if you experiment with the parts you should feel a noticeable difference & notice a change in the lap times .
*rotation , a fancy word for corner speed....
#6373
#6374
Exactly what I did. Filled shock body. Oil in shock cap. No bleed screw in cap. Put cap on and oil pushes out the bleed hole. Then as I compress the shaft I put the bleed screw in just before full compression so air can't enter. Cycle the shaft about 10-15 times and watch it retract into the body. Sometimes part way in, sometimes most of the way in. IDK.
