RC10B4.1 FT/WC
Old 09-18-2011 | 05:48 PM
  #5971
idrummerboy13's Avatar
Originally Posted by ovalracer1m
Last time I checked this was not the for-sale section. Post it where it belongs. This is car thread, not a thread to sell your crap on
i forgot you are a moderator, i would do the same maybe somebody on this thread wants another kit and doesnt check the fs section..
idrummerboy13 is offline
Old 09-18-2011 | 05:57 PM
  #5972
Kraig's Avatar
Super Moderator
Well, if you don't look in the for sale section it is your own fault.
I would strongly discourage doing this any further.
Kraig is offline
Old 09-18-2011 | 06:12 PM
  #5973
Does anyone know that on the b4.1 hex conversion so you can run hex wheels on the back if that will also work on the b44.1? Just wondering if the two cars had the same type of rear end?
dbracn is offline
Old 09-18-2011 | 07:14 PM
  #5974
RickSlick's Avatar
Default First improvement
I have a new RTR B4.1 and the only thing I've done to it is put double D tires on the back. I'm somewhat of a rookie to all this, so I ask you all this.
What would be the first thing I could do to this car that will improve performance? I am more interested in handling improvements rather than speed. I run entirely on outdoor clay tracks which vary from somewhat hard with no dust to fairly dusty once everyone has run on it awhile.
Thanks, Rick
RickSlick is offline
Old 09-18-2011 | 07:51 PM
  #5975
Thanks, Rick
i was in he same position as you 7 months back, you want to run the tires everybody is running there, get the toe in block kit that comes with all the toe in selections, run the 3.5 degree block to start and get the anti squat kit, 2 degrees or the thicker shim goes under the block. #2 pistions with 3 limiters in front and 2 in rear green in rear and add weight, one square in each rear triangle and 2 in back of the toe in blocks....good luck
Old 09-18-2011 | 09:15 PM
  #5976
Wild Cherry's Avatar
Tech Legend
Default Up Date
8M set-up
Graphite
arms, nose brace, rear chassis brace
Ft End of Car
Shocks
32.5w #2 (4 X 030) internal shims
silver ft K-spring, 24m ride height
Shock mount inside on arm, inside on tower
ball stud inside on tower (1 X .030)
30 degree caster ball stud, on inside\
Rear End of Car
Shocks
27w #2 (3 x .030) internal shims
silver rear K-spring, 24m ride height
0 degree rear hub 3 toe block , 2 degree anti-squat
Shock mount inside on arm , inside on tower
ball stud inside on chassis 0 limiter, middle hole on rear hub ,
hub installed middle of arm ....
1 1/2 oz ft of transmission , 1/4 rear sides on battery tray
1/4 oz on each side of servo
1/2oz next to receiver
track conditions = med to high traction clay
Tires
JConcept Bar Code (Gold)
Ft insert = trim rear Bomb 1
Rear insert = Pro-Line close cell
Wild Cherry is offline
Old 09-18-2011 | 09:20 PM
  #5977
Job4ACowboy69's Avatar
So Cherry, is the 8mm chassis the way to go?
Job4ACowboy69 is offline
  #5978
Registered User
The guy is obviously new to the forum. How about explaining that there is another section for selling stuff rather than blasting him.
Ryno B4.1 is offline
Old 09-18-2011 | 09:21 PM
  #5979
Tech Legend
JOB4
8m is just as fast as standard chassis , but 8m is more consistent & easier to drive , better landings...
Old 09-18-2011 | 09:27 PM
  #5980
A lot different of a set up from the std chassis?
Old 09-18-2011 | 09:29 PM
  #5981
Tech Legend
JOB , not much new really , just the graphite & K springs mostly...
Old 09-18-2011 | 09:30 PM
  #5982
ovalracer1m's Avatar
Just now seen that he had only a few posts. Maybe should have worded it a bit differently. Just gets old when people can't follow simple forum guidelines and clutter up a thread that is here to discuss a certain rc car.
On another note, got a chance to run both the rcrd aluminum chassis on the b4 and t4. Was really pleased with the chassis and the way they handled on the track. Was running a cut +8 chassis and tried the +12 rcrd chassis since the track I race on is pretty blown out and pretty wide open and flowing. B4 was more predictable all around and could be driven much harder without getting out of shape. If you want another option besides modding a t4 chassis I would definitely give these a try. As for setup, I was running a very similar setup wild cherry posted besides the springs. Ended up with orange front k springs and dark yellow rear springs.
ovalracer1m is offline
  #5983
D-Rek07's Avatar
What is the anti-squat kit?
D-Rek07 is offline
Old 09-18-2011 | 10:54 PM
  #5984
Sorry guys for cluttering up the B/T 4.1 thread with a B and T 4.1 for sale. Yes i am new to rc tech, but not the industry. And now the rc tech thing may be old news. It seems to be a bunch of the same people on here, some know what they are talking about, some pretend to, and others have no idea. I participate in the hobby to have fun, and there are a lot of people that are just no fun or take it way to serious. Lighten up..........
K-Wat is offline
Old 09-18-2011 | 11:00 PM
  #5985
Oh, and BrentH, maybe you should take a dose of your own medicine and change your signature line to just that, your signature and not an ad. If people are looking for a long chassis they will look in the for sale section!
K-Wat is offline
