RC10B4.1 FT/WC
#5221
May have been covered already but is the geometry of the new shock towers the same as the old ones as I believe the 4th hole was a pretty good setting on rear tower but had to be drilled by owner. I see the new tower has the same three holes but are they in the same location or have they been moved? Thanks for any input. Trying to update my old buggy for some winter mod action.
#5222
#5224
#5225
Also the chassis is not just for rough tracks. It is in my opinion better on all surfaces.
#5227
Here is the thing with the long chassis. The car as it comes is still very good. If you put that car in a capable persons hands that car will go just as fast as the long chassis car. With that being said the long chassis is slightly easier to get around the track, so to the middle of the road driver it will feel much better.
#5229
#5230
and the brace pieces was only like $5 and i do have a t4 brace i bought off ebay for $2, and it was factory team one too lol
#5231
just ran the worlds setup(kinda) on a similar surface on a 40 ft straight track, BEST THING EVER. hopefully my chassis will be finished idk if i can finish it tom but it will be awesome when shes done!
-30 wt losi all around,#1 pistons front #2 rear , 3 limiters in front 2 rear. 1mm rebound
Inside shock- outside arm inside tower,Rear shock-inside arm inside tower
camber locations are stock, #1 CAMBER on the square that comes with the kit all around
2.5 degree toe in .5 hubs. 2 deg anti s.
2 washers under front studs no washer under rears, proline m3 holeshots,pink hot body gigabites 2 row fronts.
try it out...
try it out...
#5232
Registered User
So I'm a little pissed. I have all my parts to convert my B4 front axles into the hex set up (just used the SC10 parts) however the wheels are not out yet so I figured I would just go with the Losi 22 fronts. I have just found that the 22 wheels use a 9mm hex where the AE kit will use a 12mm hex. This takes away the point of trying to be more universal.
Have any of you run into this problem? Are the Kyosho fronts 12mm?
#5234
#5235
AE and K run the same and Losi is the odd man out, so blame Losi not AE..
