RC10B4.1 FT/WC
Old 08-23-2011 | 11:39 PM
  #5371
RatsacK's Avatar
Originally Posted by Racer X8000
Buy a ball diff?
I've had bad luck with ball diffs so far. Are they reliable for higher power setups?
RatsacK is offline
Old 08-24-2011 | 12:37 AM
  #5372
BSchorr's Avatar
R/C Tech Elite Member
Whats the difference in running the B44 rear arms to the regular B4 rear arms?
BSchorr is offline
Old 08-24-2011 | 12:46 AM
  #5373
Jake S's Avatar
b44 arms are stiffer, they are somewhere between b4.1 and b4 carbon.
Jake S is offline
Old 08-24-2011 | 06:05 AM
  #5374
???E-Racer's Avatar
Originally Posted by 916bdogg
YEP 81/23
I'm gonna try that ratio today and see if I feel a difference.
I had a 81 tooth spur in my pit box, and I did find a 23 tooth pinion as well.
Just now switched them out.
I'm hoping it will be even faster.
Who doesnt like doing speed runs in an empty parking lot.
Next thing im getting for the car is some decent street tires.
Might as well enjoy the car before I start jumping it and breaking A-arms...lol
???E-Racer is offline
Old 08-24-2011 | 07:03 AM
  #5375
xtraman122's Avatar
I always wondered the same thing, as far as I could they were identical. Aren't they now using the same plastic on all the .1 cars?
xtraman122 is offline
Old 08-24-2011 | 07:12 AM
  #5376
MiCk B's Avatar
I can't find the post.
But someone from AE said the following
The softest arm is the B4.1
Then the B44.1 arm (Medium)
Then the carbon arm is the stiffest.
MiCk B. :-)
MiCk B is offline
Old 08-24-2011 | 07:38 AM
  #5377
Try using the SC10 4x4 internals (91007) inside your diff. They should hold up to the power better!
Chris Jarosz is offline
Old 08-24-2011 | 08:26 AM
  #5378
t4mania's Avatar
Anyone running a Novak GTB2 esc on their buggy. Plan on using a 8.5T motor so I figured I wouldn't need any advanced timing like the Tekin RS has. What do you think? Also who makes wheels for the 12mm hex conversion?
t4mania is offline
Old 08-24-2011 | 08:38 AM
  #5379
davidfast's Avatar
MiCk B. :-)
Here ya go
http://www.rctech.net/forum/8912523-post2212.html
davidfast is offline
Old 08-24-2011 | 09:02 AM
  #5380
I ran one . Good deal for $99 . BUT , I would not recommend it for buggy racing . For bashing sure . It is just not smooth enough for me to race with . I have a LRP though . Super smooth . I am not the best driver yet , so I need a smooth set up . Only had a buggy for about a Month . When I had the Novak ESC's in my buggy , I would loop out in the corners . I tried the GTB2 and a Havoc Pro . They also do not fit very well in the buggy . They also had some heat issues when I ran my 8.5 turn motor with them . Could have been gearing related though .
So , IMHO , no for racing . Ok for bashing .
I am a newbie though .
Kenton is offline
Old 08-24-2011 | 09:22 AM
  #5381
???E-Racer's Avatar
Originally Posted by Brad S.
23/81
Thanks for the help. I took my B4 to an empty parking lot for some speed runs.
After 25 mins or so it didnt thermal so I guess im good to go.
If you want a good gear ratio for an 8.5 people look no further. 23/81 is good.
I had to cut the shell some to fit my XBR esc in the car.
It's close to the same size as the Havok esc.
Old 08-24-2011 | 09:50 AM
  #5382
Jmuck69's Avatar
Originally Posted by vr6cj
Anyone try the Vented "V2" Slipper Hub Set? Worth trying out for mod?
I'm using the vented hubs in 13.5 and work well, but would be better suited for mod. They look cool anyway.
Jmuck69 is offline
Old 08-24-2011 | 10:16 AM
  #5383
What bad luck are you having?
My diff has last as long as I built my kit which was in march, still super smooth
x60Driver is offline
Old 08-24-2011 | 11:03 AM
  #5384
D-Rek07's Avatar
Is 14 gauge good enough to connect from the motor to the esc? Also is it okay to have 13 gauge on two of the motor tabs and 14 on the last one?
D-Rek07 is offline
Old 08-24-2011 | 12:04 PM
  #5385
xtraman122's Avatar
I do, it works great, no heat issues whatsoever and it fits fine.
