RC10B4.1 FT/WC
#6121
For those of you that have been waiting patiently the RCshox 2stage pistons are ready and in stock!
Also Garolite slipper pads go into testing this weekend!
for those of you not familiar with the pads they actually almost work opposite of the stock and HD pads. instead of slip/grab/slip/haze/slip, these actually slip and engage and you can even pull the wheels while its slipping. They do not glaze and offer superior wear. every few weeks just take some 600g sandpaper lightly sand and keep on going!
http://rcshox.com/shoxshop/catalog/i...hp?cPath=23_26
#6122
#6125
#6127
what i do is keep a old spur gear and a sheet of 400 grit sand paper, then put the slipper pad in between the two and hold down the sand paper while moving the spur with the slipper pad in between the two. that way your not sanding your fingertips. it only takes a matter of seconds per side of the slipper pads! wish i could take a picture of it, hope u get the idea. oh and yes u will be sanding a little off the outer section of the gear, thats why u use an old gear. pretty much the same process as sanding diff rings using a old female outdrive to hold the diff ring in place while sanding!
#6128
Emailed JConcepts about doing hex wheels for the B4 & they said yes but it will be a while. Don't really understand why so long as they always seem to be right on top of things AE does to their vehicles.Anyway thats what they told me.
#6129
Read this post...
http://www.rctech.net/forum/9633171-post4248.html
Jason testing the Inverse wheel at a Florida race.
#6130
I do the same thing you do with the diff rings so I don't know why it never occurred to me to try an old spur for the slipper pad. I imagine the more you use that old spur the better it gets for sanding a slipper pad too.
#6131
Using Yellow pads,4.1 spring & new vented slipper plates.....
#6132
Just to clarify: I don't have to, I just choose to. I don't like any glazing on my pad at all. I am actually trying to do it less often.
#6133
#6135
With lipos the weight is reduced and need to add weight back in. It also helps settle the car and make it more predictable. I tried running the b4 w/o ballast weight and it's a handful. I think with time you could run the car w/o the additional weight with a different setup, but it's easier just to add weight.
