RC10B4.1 FT/WC
Old 09-23-2012 | 01:25 PM
  #20971
bilster44's Avatar
Originally Posted by OptimumRC
Just finished a rebuild with almost everything brand new, and figured I had to share this jewelry. I almost don't want to run it, lol.
Also got to put on the new 12mm shocks...DIALED!
Optimum: Did you do a little grinding as well as the 1mm spacing on the shocks?
bilster44 is offline
Old 09-23-2012 | 01:35 PM
  #20972
Jmuck69's Avatar
Originally Posted by Atomicsickness
If you would have went you could have asked him
Grrrr... I have an inside man going to take a close up pic soon.
Jmuck69 is offline
Old 09-23-2012 | 01:37 PM
  #20973
Atomicsickness's Avatar
Looks like Dustin is using Endust instead of Pledge? Maybe Endust has less drag coefficient?
Atomicsickness is offline
Old 09-23-2012 | 01:40 PM
  #20974
Jmuck69's Avatar
You just opened that debate again. Pledge vs. endust vs. WD40. This will go on for 2-3 pages. Thanks..
Jmuck69 is offline
Old 09-23-2012 | 01:57 PM
  #20975
Wildcat1971's Avatar
Are you an AE driver? Didnt think the shocks were released yet.
Wildcat1971 is offline
Old 09-23-2012 | 02:38 PM
  #20976
skrichter's Avatar
Full pack? Not wolfpack?
skrichter is offline
Old 09-23-2012 | 02:52 PM
  #20977
Are you running the carbon front tower
Colts is offline
Old 09-23-2012 | 03:17 PM
  #20978
RCBuddha's Avatar
R/C Tech Elite Member
Default Pledge?
You guys are using pledge on the bodies?
RCBuddha is offline
Old 09-23-2012 | 03:29 PM
  #20979
CaptainHowdyt13's Avatar
Ran some off-road indoor carpet today. Both b4's were absolutely great with the Schumacher mini pins.here is my buddy running a few laps
+ YouTube Video
CaptainHowdyt13 is offline
Old 09-23-2012 | 03:47 PM
  #20980
Eli's Avatar
Eli
Originally Posted by Bob Barry
what are you guys using for battery foams when you run shorty packs? Does the short course foam work well? 1 in front 1 in the rear? Right now I have just a bunch of foams in there but I would like to make it 1 front 1 rear if possible to avoid me moving one by accident
I took the sc10 battery foam and cut in half and it seems to work pretty good, takes a little bit of force to compress the foam to push the battery in but not too much to worry about cutting more foam off.
Originally Posted by ilanstylz
Ok heading to the track tomorrow after about a two week break. Last time at the track I was having issue's with the rear end being very loose, after landing jumps and trying to get on the throttle I was always sliding out (the rear)...... What are some things I can do to eliminate this, besides the obvious throttle control, tires etc?
With the softer springs that should be less likely to happen
Originally Posted by mxracer458
What shock springs And oil and pistons you running,at sdrc I'm running Losi yellow/red combo with #2 pistons,32.5 30wt Losi oils
At sdrc, not sure if i already told you what im running but kyosho white front, 32.5 ae oil, #2 piston, 3 limiters. rear kyosho gold, 30w ae oil #2 piston, 2 limiters. If you need even more steering try the pink kyoshos. Note on the pistons im running ghea tapered pistons with the taper facing upwards. Not sure if its better then stock ae pistons or non tapered gheas but its what i had and it works but i need to compare to stock #2 pistons.
Originally Posted by spdrac430
what springs is every one using on there big bore setup and their v2's with big bore springs
See above, i run on a indoor med. bite track with a mixture of clay and dirt.
Eli is offline
Old 09-23-2012 | 03:51 PM
  #20981
Yes. Also use it on all the plastic bits.
Old 09-23-2012 | 05:22 PM
  #20982
Venom1836's Avatar
Originally Posted by Venom1836
When upgrading to Big Bore shocks do you increase your spring rate or keep it the same as what you ran with the V2's?
Also do you change the oil weight or keep it the same as V2's?
-Venom
Guess no one saw this
Lol, anyone?
Venom1836 is offline
Old 09-23-2012 | 05:56 PM
  #20983
Eli's Avatar
Eli
Lol, anyone?
Im sure in the next month this will be discussed a lot. Im going to guess you will run the same springs as you would run if you are running the big bore springs that are on your v2's. As far as oil that depends on what pistons you are running.
Eli is offline
Old 09-23-2012 | 06:10 PM
  #20984
Matt Trimmings's Avatar
Lol, anyone?
Seeing that the only people that have them are the team guys maybe this question will be best asked again in a week or two when everybody else gets ahold of them.
Matt Trimmings is offline
Old 09-23-2012 | 06:21 PM
  #20985
07Forester's Avatar
Did you solder all of the black wires yourself?
07Forester is offline
