RC10B4.1 FT/WC
Old 09-22-2012 | 10:22 PM
  #20956
OptimumRC's Avatar
Originally Posted by ryanpatrickgore
How do you get your wires so well hidden and stuck down do nicely?
I reamed a hole that went behind the servo and routed the servo wire in through the battery tunnel. To help ensure the battery wouldn't pinch the servo wires I used a cut-off wheel to dremel a channel for the servo wire to go along the inside of the battery tunnel.
Other than that I just use an X-acto blade to apply just the tiniest little specs of CA onto the chassis to hold down the wire. It's just enough to hold it down but can still be easily pulled up if needed .
OptimumRC is offline
Old 09-22-2012 | 10:46 PM
  #20957
Odin544's Avatar
Originally Posted by Bob Barry
what are you guys using for battery foams when you run shorty packs? Does the short course foam work well? 1 in front 1 in the rear? Right now I have just a bunch of foams in there but I would like to make it 1 front 1 rear if possible to avoid me moving one by accident
I'm running the big SC foam up front and three smaller foams in back. I think the smaller ones are the B4.1 foams?
Odin544 is offline
Old 09-23-2012 | 08:37 AM
  #20958
spdrac430's Avatar
what springs is every one using on there big bore setup and their v2's with big bore springs
spdrac430 is offline
Old 09-23-2012 | 08:54 AM
  #20959
ryanpatrickgore's Avatar
indoor hard pack clay
Losi silver front, white rear.
32.5 & 30wt
1.2 piston front and rear
ryanpatrickgore is offline
Old 09-23-2012 | 08:57 AM
  #20960
rigor's Avatar
Originally Posted by YankeeFan123
Dumb question, but what are you guys using to make the holes in the tires?
I got these at Home Depot for about $8 or $9. A must if you're going to be punching holes in your closed cell foams as well.
http://www.amazon.com/General-Tools-.../dp/B00004T7WS
rigor is offline
Old 09-23-2012 | 10:07 AM
  #20961
Is there a pattern to which you need to punch the holes?
JiuHaWong is offline
Old 09-23-2012 | 10:11 AM
  #20962
vicdamone11's Avatar
I run on medium bite black dirt.
FR Losi Reds/32.5/#56
FR Losi Whites/30/#56
vicdamone11 is offline
Old 09-23-2012 | 10:42 AM
  #20963
Wildcat1971's Avatar
yeah, I was looking for one of those, just could not think of the name, thx.
Wildcat1971 is offline
Old 09-23-2012 | 11:32 AM
  #20964
BIGSKI15's Avatar
How quiet is your transmisson? I know that is tough to say, but my brother bought a b4.1 Ready to Run, which has the gear diff and it is so quiet compared to my worlds car. I just built the car in august but i took the transmission apart to inspect and clean it. It did quiet down some but still not close to the rtr.
I've checked and checked my pinion and spur mesh but no matter how i set the mesh it still doesn't quiet it down.
I made sure that the diff bolt was backed off 1/8 turn from full compression.
Any thoughts, or is the gear diff simply that quiet.
I can't believe how fast the RTR is compared to my 13.5...
BIGSKI15 is offline
Old 09-23-2012 | 11:57 AM
  #20965
Rysuleod's Avatar
Try replacing the top shaft. It seems like someone tracked their transmission noise to an improperly machined topshaft before.
Rysuleod is offline
Old 09-23-2012 | 12:16 PM
  #20966
aeRayls's Avatar
Originally Posted by OptimumRC
Just finished a rebuild with almost everything brand new, and figured I had to share this jewelry. I almost don't want to run it, lol.
Also got to put on the new 12mm shocks...DIALED!
Nice!
Can you tell Lorna to put the shocks on my order already! LOL
aeRayls is offline
Old 09-23-2012 | 12:22 PM
  #20967
Jmuck69's Avatar
Everytime I do a diff rebuild I replace the main diff gear and idle gear. Every two rebuilds I replace the topshaft. I also place four dabs of white lithium grease on the teeth of diff gear. Another thing to check would be the straightness of the motor plate.
Jmuck69 is offline
Old 09-23-2012 | 01:08 PM
  #20968
+1 to lithium grease on the gear.
Old 09-23-2012 | 01:14 PM
  #20969
Jmuck69's Avatar
Looks like a new ballcup Jason is testing. Looks really beefy and appears to have a second hole. Possibly to lock the ballcup onto the ballstud?
http://events.redrc.net/wp-content/g...-ruonacaar.jpg
Jmuck69 is offline
Old 09-23-2012 | 01:25 PM
  #20970
Atomicsickness's Avatar
If you would have went you could have asked him
Atomicsickness is offline
