RC10B4.1 FT/WC
Old 08-16-2010 | 09:32 PM
  #151
Lhs didn't have 1 in stock so I ordered it from them. Will be here Thursday and assembled Friday morning. Can't wait!
BlazinB4 is offline
Old 08-17-2010 | 10:13 AM
  #152
VegasHB's Avatar
Finaly raced my new B4.1, qualified 5th out of 5 and finished 1st in main....
Had some issues in qualifying, the chassis flexes like a mofo so one of my motor wires popped off and shorted in qualifier 2. Half ass solder job I guess.
I ran the Cavalieri setup to start with, silver rear springs and 32.5 AE oil in the shocks and it was crap for the dusty clay track. Switched over to the standard setup with green rears, 25 rear oil and 30 front, threw on some jconcept double dees and the car was much easier to drive. I'd stay away from the Cav setup unless the track is super high traction.
VegasHB is offline
Old 08-17-2010 | 10:49 AM
  #153
Jmuck69's Avatar
I'm always leery of using another person's setup. It's a setup for a particular person and track conditions. That is why Cav used the carbon arms, to take away some of the bite.
I wonder if you were to use the carbon front and rear chassis braces, this would take away some of the chassis flex. Another tuning option?
Jmuck69 is offline
Old 08-17-2010 | 12:47 PM
  #154
Carbon chassis braces? Is this a new 4.1 tuning option, or has this been around for a while?
MUDVAYNE is offline
Old 08-17-2010 | 01:21 PM
  #155
kyle3333's Avatar
This has been an option ever since the first Factory Team B4.
kyle3333 is offline
Old 08-17-2010 | 02:11 PM
  #156
joelwhite's Avatar
mudvayne, it the factory team parts these are them.
http://www.amainhobbies.com/product_...e-Carbon-B4-T4
joelwhite is offline
Old 08-17-2010 | 02:59 PM
  #157
Jmuck69's Avatar
I see setup sheets indicate adding 1/2 oz there and 1/4 oz there, but how are they determining that? left to right balancing is easy to understand, use chassis balancers along the centerline of the car and place the weights accordingly. what about front to back? Do you balance in a way to give the CG dead center front to back and side to side, or is it different? do you measure overall length and divide to give centerline?
would you use this to balance?
http://www.amainhobbies.com/product_...lancing-Tool-2
or some other means?
What is everyone's take on this?
Jmuck69 is offline
Old 08-17-2010 | 10:28 PM
  #158
Does anyone make X-rings for the new (or old for that matter) Assocaited shocks? Thanks!
adam lancia is offline
Old 08-17-2010 | 11:11 PM
  #159
RA99GT's Avatar
http://www.mcmaster.com/#90025k123/=8gb2so
RA99GT is offline
Old 08-18-2010 | 12:30 AM
  #160
aeRayls's Avatar
Placing the weight on the chassis side to side (like when you add the 1/2oz by the reciever) is to balance the chassis because the esc side is way heavier, ie...theres an inbalance. When we're putting the weight centralized (like in front of the tranny or on the front bulkhead) its not to "balance" out the chassis. Its too affect the handling in a desired way. Like adding weight to the front or rear slows the reaction of that end of the car.
aeRayls is offline
Old 08-18-2010 | 03:14 AM
  #161
Originally Posted by RA99GT
Nice..have you or anybody else tried these?
kwiksi is offline
Old 08-18-2010 | 05:10 AM
  #162
scottk's Avatar
Hi guys i believe the b4.1 comes with 25 degree castor blocks ? If you order 30 deg ones do you get the updated version with the 3 mounting holes etc ? Say from amain or tower
cheers
scottk is offline
Old 08-18-2010 | 05:15 AM
  #163
Thanks for the link RA99GT. Going by the durometer rating they seem like they might be a bit on the hard side. Have you tried them?
Old 08-18-2010 | 05:17 AM
  #164
occ
I just opened my B4.1 FT kit and noticed I have two rear wings? Is this normal?
I dont see any difference between them.
occ is offline
Old 08-18-2010 | 05:30 AM
  #165
Jmuck69's Avatar
Bonus!
Jmuck69 is offline
