RC10B4.1 FT/WC
#902
need some help with setup
my set up is this MMP/13.5ballistic
FT b4.1
MMP/13.5ballistic
-1camber all around
30 degree castor's
.5hubs 2.5 toe block /2.5 anti-squat
brown front/ green Rear springs, 30wt all # 2pistons all
geared 28/75
18degree timing on ESC from 6000-50000
Groovy/double-dee's
loose ball diff
medium wheelbase
everything else is FT set-up
the problem is i need to drop 1 more second off my lap times. or id be happy with .5 sec. I'm just as fast as the quicker guys down the straight and through the jumps. so i'm thinking my corner speed needs to be more.. anyone see anything wrong with my set-up? go to 0 hubs? more/less timing? i'm temping at 110 on motor/esc
indoor clay
whats everyone running for Castor blocks? 25 or 30? also what rear hubs? and toe block?
FT b4.1
MMP/13.5ballistic
-1camber all around
30 degree castor's
geared 28/75
Groovy/double-dee's
loose ball diff
medium wheelbase
indoor clay
you can save some $ and just get the b44 plastic hubs, they are .0
#903
FT b4.1
MMP/13.5ballistic
-1camber all around
30 degree castor's
geared 28/75
Groovy/double-dee's
loose ball diff
medium wheelbase
indoor clay
FT b4.1
MMP/13.5ballistic
-1camber all around
30 degree castor's
geared 28/75
Groovy/double-dee's
loose ball diff
medium wheelbase
indoor clay
#910
Hey all, I'm looking to get back into this RC thing, and I like the buggies. Since the B4.1 has been released, a lot of people are selling factory team B4's for dirt cheap! My question, is has anyone noticed a major difference when switching from a B4 to a B4.1? Have your lap times decreased at all? Any noticeable difference in durability? Thanks!
#912
FT b4.1
MMP/13.5ballistic
-1camber all around
30 degree castor's
geared 28/75
Groovy/double-dee's
loose ball diff
medium wheelbase
indoor clay
FT b4.1
MMP/13.5ballistic
-1camber all around
30 degree castor's
geared 28/75
Groovy/double-dee's
loose ball diff
medium wheelbase
indoor clay
First thing I see wrong is your timing...6000-50000!?!
Try 5000 to 20000. Your 13.5 will never see 30,000 rpm on 2S.
I'm suprised your running that hot aswell. Mines temping 90 degs with 40 degs of boost using a RS/13.5 Orion with the same gearing. Stepped up to a 32 pinion for next weekend, see where I'm at after that.
Proline Scrubs are the hot front tire locally atm...I'm running Holeshots on the rear of mine, I've tried Switches Clay/Soft, blue Barcodes, M3 Calipers, green Goosebumps so far...
#913
what would the proper gearing be for the b4 with a 13.5? i was looking in the manual and it says 81/20 but im also reading on here 78/29 so im confused on which one to start with
oh and i have the sxx comp v1 right now
#915
