SC10 Thread
#9031
I agree, the weight of the sc10 is to heavy in the front to lift that much, I never have been able to get it to do that but have done real well racng it for the past 2 years using his recommended method of a half to 2mm of thread showing. Mines usually around 1 mm.
#9032
"So, this is a big old dirt roadcourse/roval? Interesting."
Sorta...
It just has a long 180* mostly WOT right hand sweeper at each end of the track. First one leads onto the front straight, which leads onto the second one. The first one has a big table top (about 4' tall and the crowns conform to the turn... making the "table" trapezoid shaped) in the middle of it and the second leads into a sacrifice jump into a 90 right that brings you into the road part of the Roval. It never gets raced as an actual oval. It's not banked or anything. I'm honestly not sure what the guy that made it was thinking. I know he has a lot of history locally with racing RC's in various parking lots and that sort of thing and really the whole thing seems very road course like. I'd like to see it changed up a bit and that's the plan in a few months. We're going to dig up the top 6" or so and sift it to get the rocks out and then re-do the layout.
Sorta...
#9033
It's terribly hard to understand what you're saying here due to quite a few spelling and grammar mistakes...
Regardless, with some track conditions traction will always be low enough to allow your described situation if you're not careful with the throttle. Soft springs and weight back should help, no doubt, but what's the ride height like on your truck? What tires are you running/what compound? Most importantly, what kind of track conditions are you running on?? (gotta mention these things up front to stand a chance of getting answers).
#9035
Can anyone recommend some alternative tire inserts?
The JConcepts closed cell foams seem to be too stiff and too small to fill out the tire, the proline closed cell ones seem to be a bit too stiff but fill the tire nicely. I bought a package of orange Ofna 1/8th scale foams, and they are too narrow and much too soft.
I put the stock FT SC10 front white molded foams in some suburbs and put them on the back, and now I don't have any steering and have great forward bite. I like them.
Are the AKA red foams softer than the prolines? I've fondled some panther switch tires with yellow foams, and they seem about right. But they don't appear to be available separately from the tires.
Any ideas?
Any ideas?
#9036
Any ideas?
Any ideas?
I love them. work well
I also run Jconcepts blue foams.
The AKA are easier to find though
#9037
Do you only run those aka foams on the rear or all around? I'm just now going to start experimenting with softer foams in the rear. I been running on hard, dusty, extremely low traction surfaces and need help getting grip.
#9039
I've seen this on another forum and it's caused by people trying to put an old T4/B4 ball diff into the new SC10/T4.1/B4.1 diff case, which doesn't work because the case and outdrives have changed (as Asharus explained). There are two solutions:
1) Buy new outdrives and bearings. This is a fairly expensive route.
2) Buy the T4/B4 ball diff case and a T4/B4 rear chassis plate. This is really cheap (5-6 bucks), but could leave you or a future owner very confused.
I hope this helps.
I hope this helps.
#9044
Are you meaning to say how you can adjust droop? If so, then you would need to run limiters inside the shock bodies.
If a B5/T5 ever comes out, it would be cool if they had a droop screw option so you can adjust droop settings without putting limiters inside the shock body.
#9045
I want to lower the truck but I want to keep some pre lad on the springs. I've seem videos of people using fuel line to limit the amount of piston travel in the shock. I was wondering if that was a feasible option? Also where do you measure the ride height of the truck on the body?
