SC10 Thread
Old 01-21-2012 | 07:03 AM
  #9181
kbr
Originally Posted by JEFFs SC10
bet that thing jumps funny lol
yeah nose heavy an dont know why
kbr is offline
Old 01-21-2012 | 07:06 AM
  #9182
kbr
Originally Posted by kc_nitro_rc
Where is the front camber link mounted at the tower & outside at the wheel?
Also, make sure your rear hubs are forward.
inside on tower inside at wheel an wat u mean by hubs foward
kbr is offline
Old 01-21-2012 | 07:36 AM
  #9183
Lake Ober's Avatar
Just a quick question to see what you guys do about situations like this:
I recently have only been able to race 1x a week at my local track. However, often when I leave the track, both of my two LiPo batteries (2s) will be fully charged. I have been just letting them sit for the week, fully charged, and have not been putting them in storage mode for the week. Now, I would assume this wouldn't hurt anything, but I just wanted to check with you guys before I continue to do it. Will doing this potentially decrease the life of my battery or cause any harm to it? Thanks!
Update:
Just did the hex conversion on my FT last night... using all AE parts, with the exception of JConcept adapters in the rear. Lovin' it!
Lake Ober is offline
Old 01-21-2012 | 09:11 AM
  #9184
Originally Posted by jamr1130
For clarification were these springs used on his SC10 or B4.1? Anyone know the Kyosho spring pt#s?
I know they were on his truck, not sure on the B4.1. Don't know #. Cavalarri had them on his truck too. Red rear, not sure what color on front. I know he didn't have red on front.
Bdabuck is offline
Old 01-21-2012 | 09:14 AM
  #9185
kc_nitro_rc's Avatar
KBR-
Go back to the base SC10 setup.
Things to check-
Diff. Hold spur gear & spin tire on one side. Other side should spin about one revolution then come to a stop. If it rolls more diff is to loose. If it only rolls about a half turn your diff is to tight. Does your diff feel gritty? Might need rebuilt.
Rear hubs forward. Where they mount in the A-arms. Should be two shims. I have the Factory Team truck. Don't know about the others. Put the two shims to the rear. Moves the hub forward. Gives you more push coming out of turns.
Front camber link is in proper location. Remove any shims under the ball studs on the tower.
Tires- Double Dees on front, Bar Codes on rear. Or similar combination. AKA Grid Irons front, Wishbones or Rebars rear.
kc_nitro_rc is offline
Old 01-21-2012 | 10:08 AM
  #9186
bzb
Update:
never leave fully charged, try 3.6 v (7.2 per pack) per cell for storage for longer life
bzb is offline
Old 01-21-2012 | 10:21 AM
  #9187
brent701's Avatar
Update:
It's going to be a Huge matter of opinion.
I use mine to much to leave in storage mode.
Some discharge them. some don't.
I use my cars to discharge mine and just don't charge them back up when I am not going to use them. Mine only sit charged for about a day before they get used again.
oh and Lake.
I took 1st, 1st and 1st last night at the races
brent701 is offline
Old 01-21-2012 | 12:04 PM
  #9188
kbr
KBR-
Things to check-
okay thanks i will try that any thing will make it better some how any mor advise would help
kbr is offline
Old 01-21-2012 | 01:15 PM
  #9189
KBR-
Things to check-
Diff. Hold spur gear & spin tire on one side. Other side should spin about one revolution then come to a stop. If it rolls more diff is to loose. If it only rolls about a half turn your diff is to tight. Does your diff feel gritty? r.
Thanks for this!! Helps me a lot.
Mark
mark in wi is offline
Old 01-21-2012 | 01:34 PM
  #9190
JEFFs SC10's Avatar
Actually got my truck working good in a low traction,bumpy, dusty surface today. What helped alot was altering my throttle.curve to take.the bottom.end out so it wouldnt spin. Moving the camber link inward helped me come out of turns better instead of spinning out.on exit.
JEFFs SC10 is offline
Old 01-21-2012 | 01:49 PM
  #9191
JEFFs SC10's Avatar
Do the hexes in the rear.slide over the pin? I obliterated a set of brand new wheels today. My fault though lol.
Old 01-21-2012 | 01:52 PM
  #9192
Jerm13's Avatar
Yes. Some clamp down on the axle and some just slide over the pin.
Jerm13 is offline
Old 01-21-2012 | 02:12 PM
  #9193
kbr
thanks for the sort of test lol to rainny to race in nc how bout a setup sheet for future notes
kbr is offline
Old 01-21-2012 | 02:49 PM
  #9194
JEFFs SC10's Avatar
tried loading up my setup but its too big . stupid pdf's lol
Old 01-21-2012 | 03:58 PM
  #9195
xtraman122's Avatar
Picking up an SC10 for the first round of the SC Showdown at my home track coming up in March, what have the setups been for using Losi BB springs?
I'm all set up now on my buggy, but I'm just trying to figure out what would be equivalent to a Green and Gray rear and a Red, Gold, and Blue front. Pink Losi rear seems to be like an Ae Green, what do you guys think to match a Gray Ae rear, go up to Orange?
I'm lost on truck fronts; haven't touched an SC10 or T4 in almost a year.
xtraman122 is offline
