SC10 Thread
#8431
Based on my experience with an older SC10, the main things that will break are arms and the front bulkhead. The old arms (and I believe the front bulkhead, but someone else should confirm this) are nowhere near as tough as the new ones (from AE, not even RPM). As we've swapped out the old arms that broke for new ones, we haven't had to replace them again because they just don't break.
#8432
Having a little issue with my sc10. It handles great, but sometimes the wheels bottom out on the body, and my body is raised up in the back till i can't raise it anymore. I am running 40 weight all over and running on carpet. built my shocks with 1/4 rebound and running red springs front, silver rear. Can anyone help?
#8433
#8434
hey guys im getting a sc10 ft from the wife for christmas.
now i have never raced 2wd sc before so im looking for a little help. i have 2 options on electronics to put in this truck. i want to run mod 2wd so i was looking to put in an lrp ssx v2 tc with a reedy sonic 7.5t, or a tekin rs with a redline 10.5. im not sure on how the truck will handle the 7.5 or what gearing would be a good starting point. I also wanted to know if you guys are running ball diffs or gear diffs? thanks again for any help you can offer.
Dan
now i have never raced 2wd sc before so im looking for a little help. i have 2 options on electronics to put in this truck. i want to run mod 2wd so i was looking to put in an lrp ssx v2 tc with a reedy sonic 7.5t, or a tekin rs with a redline 10.5. im not sure on how the truck will handle the 7.5 or what gearing would be a good starting point. I also wanted to know if you guys are running ball diffs or gear diffs? thanks again for any help you can offer.Dan
#8435
Dan
#8438
Dan
#8439
Dan
#8440
Dan
As far as the power goes, it doesn't hurt to buy too much motor IF you are willing to turn the power down. If not, you will beat the crap out of your truck and get really frustrated. Many times, slower is better.
#8441
Thanks for all your suggestions and opinions. I'm not new to racing, just never raced 2wd sct. I race 2wd durango buggy, and a losi scte. I may just put a 17.5 and boost it little by little to get familiar with the truck.
#8442
Dan
I'm partial to Tekin ESC's. Started with a 10.5 Redline in my SC10FT. It's an indoor track, usually tight & technical. Geared mostly 21/84. Decided to motor up. My only other motor is a 6.5. Nice thing is I can 'tame it down' with the Tekin RS. It's geared 18/84. I can get 10 minutes track time and both motors come off about 140-150'. Your results may vary.
Definitely the ball diff. Follow the setup guide on this site.
Hope your wife enjoys her new truck. It's always nice to see husband & wife both involved.
#8443
Probably not the answer you wanted. So here is another- duct tape under the body where the tires hit.
#8445
Are the gear diffs still that bad durability wise? I've been a serious racer all my RC life, but have been itching to build a car for the sand dunes that pepper quite a bit of MI. A 2wd sct with a jconcepts Bajr body and 4 pole motor has been slowly assimilating itself on the corner of my work table and since it's just for funsies a low/no maintenance gear diff is next on the list of items to feed it by spring time.
