SC10 Thread
Old 12-11-2011 | 05:28 PM
  #8401
Originally Posted by idrummerboy13
Somebody throw me a setup for this truck please. It does not feel good. Got 2nd in main but still. I was going slow to keep in from sliding.
RED springs 30 weight oil with #3 pistons, shocks inside on tower out on arm
camber link was inside on tower 2 spacers underneath, first on castor block, 2mm bumpsteer. Steering block in middle. 7 limiters
Silver springs 32.5 oil with #1 pistons 3 limiters. inside on arm, 4th hole drilled on tower. link is inside with 1 washer, outside on plastic hub.
-1 camber all around, 3.5 degrees of toe, 2 degrees of anti squat, ball diff is med set. Soft wishbones in rear, super soft rebars in front.
Med high bite.
Try blue f springs,30/25 oils,"c" rear hub towers, ride height 29mm.....and try some hb neams for tires. I hated wishbones...never hooked up
nitro0619 is offline
Old 12-11-2011 | 05:35 PM
  #8402
HighLife420's Avatar
Originally Posted by 20 SMOKE
you dont use turbo in offroad,there is a 17.5 setup on tekins site,you can start with timing profile 3 with 12 on the motor geared around 25-27/74
Thanks smoke, was thinking that...but wasnt sure.
HighLife420 is offline
Old 12-11-2011 | 05:59 PM
  #8403
Chad Smith's Avatar
Ok was thinking of going with a savox 1258TG but I heard that servo is power hungry and causes glitching. I am running a LRP sxx v2 line of esc's will that esc be able to supply enough power for that servo?
Chad Smith is offline
Old 12-11-2011 | 07:00 PM
  #8404
idrummerboy13's Avatar
ok thanks dude. will try out, also will change gearing, my 13.5 is geared slow to equal up to 17.5 but for now ill throw my epa down and test the diffrence. I feel like the esc behind battery isn't as good as putting it on the side. Idk..
idrummerboy13 is offline
Old 12-11-2011 | 08:03 PM
  #8405
Never tried movin the esc...i do run about 4oz lead behind battery though
Old 12-12-2011 | 12:29 PM
  #8406
kbr
Originally Posted by Asharus
Will 81/28 fit the motor plate? I normally run a 75 26-28 on my blinky 17.5 but a friend wants to race with me so I swapped the 10.5 motor out of my 2nd SC10 to a 17.5 but don't have another 75 spur at the moment.
how caan u all i can fit is 81/22
kbr is offline
Old 12-12-2011 | 12:49 PM
  #8407
Asharus's Avatar
Med high bite.
Did you have on-power push? I had rebars on and it pushed bad. I changed to a "secret" tire and now my rear end can slide out if I don't release the throttle on the first turn after the straight.
I will tell you what my secret tire is once you change to a 17.5 motor and become legal to race in our class
Asharus is offline
Old 12-12-2011 | 12:51 PM
  #8408
Asharus's Avatar
i have not confirmed that 81/28 will fit, i do have another 75t coming. i may have to try 81/28 tomorrow night if my friend wants to race.
Asharus is offline
Old 12-12-2011 | 01:22 PM
  #8409
The Savox caused very slight glitching with my Novak ESC, since then ive used the glitch buster from spek, no problems at all.
Old 12-12-2011 | 01:28 PM
  #8410
Asharus's Avatar
I have 4 Tekin RS setups with 2 Savox 1257 and 2 1258s. Identical receivers, either a 92744 or the 92451 Airtronics. 2 out of the 4 need a Spektrum cap.
They didn't glitch either, the motor cogged at low speeds without the cap. No cogging with the cap installed.
Asharus is offline
Old 12-12-2011 | 01:50 PM
  #8411
that will be soon, I will try some barcodes since i have em but they are a little worn but they should be fine. And no it was loose in the back, and could not turn well.
My b4.1 was easier to drive I have to catch fraiser me and him are truely so close but his car is a lot easier to drive. Really nice guy hes so fun to race against. I just think its setup. And just got updated by don i will get a 17.5 viper from him. I wont race sc untill than. My novak is such garbage.
Old 12-12-2011 | 02:14 PM
  #8412
Are you running any boost or timing advance? I tried timing profile 3, but it doesnt add any timing advance, just boost and rpm range.
Old 12-12-2011 | 04:07 PM
  #8413
forwardonly's Avatar
I run the savox servos and love them. You will want a power cap such as the Novak Glitch Buster or the Spektrum power cap.
forwardonly is offline
Old 12-12-2011 | 08:14 PM
  #8414
WillD's Avatar
Thumbs up
I run 1258's in both my SC10 and B4.1 on LRP SXX esc's and neither have experienced any glitching
WillD is offline
Old 12-13-2011 | 10:04 AM
  #8415
I run the 1258 on both my SC10 2wd and B4.1 and 1256 on my SC10 4x4. When I was running Spektrum tx/rx I threw on a Spektrum glitch buster ($8) and had no issues at all. I am now running Airtronics MX11 tx/rx and have since eliminated the the glitch buster. Great servo with good balance of speed and torque.
jamr1130 is offline
