SC10 Thread
Old 12-26-2011 | 09:09 PM
  #8581
Lake Ober's Avatar
Originally Posted by njnewc
No you don't shim the Diff, it will work perfect if you build it right, There is a thread on here about how to build it. I will find it and send you a link. I would not put the RPM arms on there. I have had a few FT SC10's and have not broken a arm yet. The RPM stuff is very durable but for racing purposes it is not needed... I have RPM bumpers on my trucks now, it makes the front end pretty durable.
The stock tires that come with the FT truck are pretty good, at least the rears are. They are JConcept Sub Cultures I believe. I run HB Beams front and rear and they are the best that I have found IMO.
I also have 12mm Hexes all the way around. I use the proline set up because that was all that was available at the time. I know you can get the RS setup on ebay or some other sites for cheaper. The benefit of this is strength factor on the rear. The pin rears on the stock FT tend to strip. Also if you put these on the front and rear you can interchange your tires. The fronts and rear will run the same rims. So this will give you more options with tires.
I run a VIPER VTX10 ESC, I personally love it. I run a few different motors and haven't had a bad one. Reedy Sonic 17.5, Viper VST 17.5, Icon 17.5, etc... I know the Tekin RS and RS pro are great ESC's. I would personally stay away from Castle and Novak. But again just my opinion.
Make sure you get a good servo, these trucks turn on a dime so take advantage of it.
Sorry for writing so much, hope it helps
Tim
I don't mind the long post at all, I need all the help I can get So, yeah, maybe I will leave the RPM's off for now and see how the FT arms handle. A lot of people have said the RPM's aren't so hot for racing.
If you don't mind me asking, what wheels are you using? Stocks, beadlocks? Also, what is a good servo you would recommend?
And also, if you could send me a link to that post you were talking about, that would be GREAT! Hope to hear back from you.
Lake Ober is offline
Old 12-26-2011 | 09:36 PM
  #8582
njnewc's Avatar
http://www.rcshortcourse.com/forum/t...fect-diff.html
Here is the link. I have used this numerous times. Works perfect every time.
njnewc is offline
Old 12-26-2011 | 09:38 PM
  #8583
Lake Ober's Avatar
Thanks man, this is great!!
Old 12-26-2011 | 09:50 PM
  #8584
brent701's Avatar
watch these
http://www.rctech.net/forum/electric...er-clutch.html
RPM arms are good for bashing. Most people do not need them for racing. You hit less crap. well try to anyways.
Rims. I use the Stock RS rims. and DE racing rims.
I just tested out a set of Jconcept hazard rims with the 3mm offset. on my 4x4 and 2wd and they worked great..
servo
Can't go wrong with a Savox 1258TG
I know the questions above were not toward me but the more info the greater in the long run.
brent701 is offline
Old 12-26-2011 | 10:11 PM
  #8585
Lake Ober's Avatar
Originally Posted by brent701
watch these
servo
You guys are awesome! I just came from posting on the Traxxas forums (for my Mini Erevo) and you guys on here are wayyyy more helpful then on there!
So, I checked out those videos, and of course... bookmarked them for once I receive my kit in the mail. I think they will come in handy greatly.
One question, what DE rims specifically will work on the FT SC10, and will I need adapters? Also, the FT comes with subcultures for the rear, and I would like to also install them on the fronts. Do you know what size I need to get? I was looking on tower hobbies, but they had a few different sizes and I wasn't sure which ones I'd need. Thanks!
Old 12-26-2011 | 10:18 PM
  #8586
brent701's Avatar
You need to get the rims for the FT kit. rear pin style (Non-Hex) front non-hex. the bearings go into the rims.
the tires you are looking for are these.
http://www3.towerhobbies.com/cgi-bin...?&I=LXAACX&P=0
You need any SCT 3.0"x2.2" tire
Your part numbers for the rims are
Front - 3317
Rear - 3318
those are non-hex rims. for the SC10 FT kit
If you wanted to upgrade to Hex.
I would run the Jconcpets rear 12mm hex
I would also do the stock RS front conversion instead of the pro line (I like to stay as factory as I can with stuff)
Need RS steering blocks
Hex kit from AE or anyone else that uses them. I use the plastic AE ones. I found the others add offset to the front.
RS Hex axles
ball stud lock nuts.
use the same bearings from your wheels in the hubs.
this is just in case you wanted to upgrade.
If you do. don't mount your tires on the FT rims. lol. might as well get Hex rims and mount them on there. lol
brent701 is offline
Old 12-27-2011 | 07:09 AM
  #8587
forwardonly's Avatar
One question, what DE rims specifically will work on the FT SC10, and will I need adapters? Also, the FT comes with subcultures for the rear, and I would like to also install them on the fronts. Do you know what size I need to get? I was looking on tower hobbies, but they had a few different sizes and I wasn't sure which ones I'd need. Thanks![/QUOTE]
You can do some of this research by checking online stores like Amainhobbies.com. Go to Cars and Trucks, then Parts, choose Associated, then SC10 and there are hundreds of parts and accessories for this truck. You won't have to ask which one fits because you will be looking at all the stuff you can put on this specific vehicle. I love doing this and I waste lots of time window shopping this way.
Good luck and have fun!
forwardonly is offline
Old 12-27-2011 | 07:12 AM
  #8588
Lake Ober's Avatar
Front - 3317
Rear - 3318
RS Hex axles
I think I am going to put the 12mm hex adapters on my FT SC10, because I am interested in using the Pro-Line Split Six wheels. I have always been a fan of the beadlocks and would like to get them again. Do you know what the part number is on the 12mm hex adapters that fit on the FT SC10?
Old 12-27-2011 | 07:15 AM
  #8589
Lake Ober's Avatar
Good luck and have fun![/QUOTE]
Yeah, I was thinking that exact thing when I couldn't find that info on tower hobbies... so I went to thetoyz, but they didn't have more then one or two rims listed under the SC10. I will try amain, they must have a better amount of stuff listed under the sc10
Old 12-27-2011 | 07:28 AM
  #8590
1Fastpede's Avatar
Originally Posted by 20 SMOKE
there a different height and changes the bump steer
EFFECTS OF BUMP STEER
More bump steer
(wheels more parallel under
compression)
• Increases steering in mid-corner
• Steering may become “twitchy”
• Easier to control on smooth tracks
Less bump steer
(wheels open more under
compression)
• Decreases steering in mid-corner
• Smoother steering response
• Better on rough or bumpy tracks
So basically hes speaking about the studs on the ackermann bar
1Fastpede is offline
Old 12-27-2011 | 07:31 AM
  #8591
nadan805's Avatar
The screw holes for my front hinge pin brace are stripped. What's the best trick to keep them from backing out before I can get a new part?
nadan805 is offline
Old 12-27-2011 | 07:51 AM
  #8592
@nadan805, pick up some blue thread lock from a hobby store, i use it on almost all of my screws on my vehicles.
jstump is offline
Old 12-27-2011 | 08:07 AM
  #8593
brent701's Avatar
Rear 12mm Hex - Jconcept #2081
Front part #'s I am using Factory RS parts. I like keeping things factory if I can
Steering block - #9880
axle - # 9881
Ball stud is long silver #6277
Locking nut for ball stud # 4449
12mm Hex #9883
The bearing # is 3977. You can use the ones in the rims. Same bearing, to save a few bucks,
The Hex kit comes with front/rear hex. You can just use them. I am not a fan of the rear plastic hex though.
You can also run different locking front hex. I don't. It makes the front to wide for me. I have the plastic ones with a small hole drilled in it to and a pinion set screw in it. They like to come off with the rims. No real big deal though
Hope that helps
brent701 is offline
Old 12-27-2011 | 08:10 AM
  #8594
brent701's Avatar
Pretty much every rim on this page
http://www.deracing.net/store/index....ry&path=62_122
The DE Racing 4x4 rims are the ones you want to use if you have HEX.
brent701 is offline
Old 12-27-2011 | 08:21 AM
  #8595
Cain's Avatar
Tech Legend
if I recall correctly its the bulkhead they screw into that is plastic correct?
If so, put some shoe goo on the screws and thread it in.
You should be able to back them out when you need to, but they will hold.
In a pinch, I have used pieces of thin paper and screwed those in for other screw hole issues. Not sure if that would work out though since the screws are so small.
Cain is offline
