SC10 Thread
#1681
chea..cough, cough, cheat..cough, cheaters.
Now no more tire excuses?
Maybe now I'll have an excuse, I won't have cheater tires in the stock class.
Oh, wait.
Now you'll have to run in the Mod class with all the mondo powered, psycho trucks. Put yer helmet on, it's gonna be a rough ride.
#1682
Oh, wait.
Oh, wait.
#1683
The upgrades are the CVD's but there not cheap and not foolproof.
CVD
http://aedownloads.com/downloads/item_photos/7383.jpg
Dogbone
http://aedownloads.com/downloads/item_photos/7361.jpg
CVD
Dogbone
#1685
i have tried running slash beadlocks on the sc10 and as stated the rears work with hexes, but on the front, the bearings and axle arnt your only issue..the offset is completely wrong and the tyres hang out the gaurds about 10mm.. or 3/8 to you guys. even trying the slash rear wheels didnt fix the track issue. would need to run shorter arms... not worth the fuck around. they do look alot better though.. give it time, aftermarket wheels will be on the way
#1687
t4 arms are notoriously brittle in the hands of unseasoned driver!! but did you know the GT2 arms are almost a direct fit and are damn near bullet proof. all the geometry is the same but you must use a gt2 outer hinge pin. rpm arms are great if your bashing but not so good for racing, they seem to make the truck feel real lazy
I just got all the GT2 stuff but I soon realized the rear shock mounts are much higher on the arms? What are you guys doing about this?
#1695
I moved the shock to the front of the shock mount also, I don't know if that will work when I change the holes in the arms?
