SC10 Thread
Old 07-02-2009 | 02:04 PM
  #1831
Double Dee's Avatar
Originally Posted by LWracer
I've raced AE cars sence I started racing and am strongly looking into the sc10. I've looked threw alot of the post here but am looking for a race setup for it. It would be on a meadium sized track run wet with a 17.5 motor, and 40c 5000 packs. I know about the tire thing but want to see it i can make it fast on the stock ones.
Thanks for any and all input.
My video will show a novak 8.5 on small in door med clay track http://67.199.85.166/racing/setups/s..._ocrc_2009.pdf . I run 30 degree caster blocks and t4 cvd also b44 rear hubs bearings and crush tube that. So with a 17.5 you should be good to go. all other parts are stock. Good luck on the build. also the truck can only do as good as you drive it. This is a Vid of my SC10 with all stock parts and set up from the box. Stock tiers will not work for a few laps http://www.youtube.com/watch?v=1KIDvdVtMKk
Double Dee is offline
Old 07-02-2009 | 02:25 PM
  #1832
grouch's Avatar
PT, that video cracks me up. Seeing your SC10 clear the triples is awesome. No running start, just pure get some.
grouch is offline
Old 07-02-2009 | 02:26 PM
  #1833
LWracer's Avatar
Thanks. I've got the driving thing down. lol But are the b44 hubs with the crush tube a direct fit? will i need new bearings or not? Your truck looks dialed and the wheelies are great. looks like the 8.5 is a bit much for the tight track.
LWracer is offline
Old 07-02-2009 | 02:35 PM
  #1834
Double Dee's Avatar
Yes i drive little crazy most the time
Yes you will need the outer bearings only. bigger and stronger. Ya big power is how I roll. Ill show you a pic of my tiers now that work awsome
Old 07-02-2009 | 02:39 PM
  #1835
LWracer's Avatar
Not to b a pain but do you know the part #s for all 3 things?
LWracer is offline
Old 07-02-2009 | 02:57 PM
  #1836
Double Dee's Avatar
hubs set 9730 bearings 7935 X2 tubes set 7933
Old 07-02-2009 | 03:00 PM
  #1837
LWracer's Avatar
Wow those tires look toasted! Thanks for the help.
LWracer is offline
Old 07-02-2009 | 03:19 PM
  #1838
LWracer's Avatar
One question on the hubs. Do they increase the toe any or did you but them on for durabilty?
LWracer is offline
Old 07-02-2009 | 03:20 PM
  #1839
Double Dee's Avatar
Thay dont work tell thay look that way LOL
Old 07-02-2009 | 03:24 PM
  #1840
Double Dee's Avatar
Ok have a good weekend. Durabilty only never played with toe becouse I run stock truck times with my MOD motor SC10
Old 07-02-2009 | 03:27 PM
  #1841
LWracer's Avatar
Oh ok. Thanks.
LWracer is offline
Old 07-03-2009 | 08:45 PM
  #1842
Anybody heard a word on bead-lock rims?
Krio is offline
Old 07-03-2009 | 08:55 PM
  #1843
Just wondering what size pinion would match the stock 75 tooth spur with the castle 4600 motor?..Thanks
xv-townboy is offline
Old 07-03-2009 | 10:12 PM
  #1844
havatitan's Avatar
Start with a 17 pinion then check your motor and esc temp after 5 min. don't let them get over 170 deg. too often or they will not last too long.
havatitan is offline
Old 07-03-2009 | 10:17 PM
  #1845
reenmachine's Avatar
http://www.prolineracing.com/p-697-s...-for-sc10.aspx
reenmachine is offline
