SC10 Thread
Old 07-06-2009 | 11:08 AM
  #1861
LWracer's Avatar
Could someone post up some picts. of how they laid out the weights of their trucks. Or a good discription.
LWracer is offline
Old 07-06-2009 | 12:29 PM
  #1862
Hey guys, as I look through rc magazines I see the SC10 all over the pages and I want one more and more. As I look closer at it I started noticing that it looks very similar to the T3/T4. I started wondering how hard and how much it would take to convert a T3? Other than the body posts, bumpers, wheels and tires it only looks like the main difference is maybe shock towers. Even if the bumpers wouldn't bolt up I guess the other main part is wheels, is the axle size and bearings the same as the T3? Maybe some of you that have had a T3/T4 in the past might know.
dont slow down is offline
Old 07-06-2009 | 12:31 PM
  #1863
DarthRacer's Avatar
I haven't owned a T3/T4 before, but I have seen the cost of converting a T4 and for the $$$ you are better off picking up an RTR SC10. That is my opinion anyway.
DarthRacer is offline
Old 07-06-2009 | 04:48 PM
  #1864
Originally Posted by Crawler
Aluminum Parts: Other than a Cuda, or Looney chassis brace.
I've found the front brace uneccasary. There are 3-4 SC10's at my local track among all Slashes.
No issues with any front ends. We do play rough. Turn outs on race day have been about 3 heats of SC lately.
kwiksi is offline
Old 07-06-2009 | 06:52 PM
  #1865
Knowneck's Avatar
Anybody got a good gear setup for a brushless 17.5 ,pinion and spur, lipo all that mid size track ,loose and hard dirt Thanks.
Knowneck is offline
Old 07-06-2009 | 07:03 PM
  #1866
balistic's Avatar
I have lawn darted mine hard enough to break the front bumper and I didn't break the chassis. That didn't stop me from putting the brace on, I don't want to miss a heat or main ever. particularly if the failure was preventable.
balistic is offline
Old 07-06-2009 | 07:09 PM
  #1867
Crawler's Avatar
Glad to hear it, but if you break one, I'll bet you wish you had.
I agree. I'd rather be safe than sorry.
Crawler is offline
  #1868
BuggyKing's Avatar
Ya I got about 2.5 months on my SC10 with the stock chassis still kickin.
BuggyKing is offline
Old 07-06-2009 | 08:39 PM
  #1869
F N CUDA's Avatar
Aluminum Parts: Other than a Cuda, or Looney chassis brace, and the ST Racing rear hubs(SCT584-T1B) w/ 1 degree of toe built in, aluminum parts are not really necessary.
Crawler, me AND Loony thank you for the props!
Originally Posted by psychopat
any chassis brace is a must! f n cuda makes one i believe.
Thank you psychoman!
At least you know it can happen.
Many of the broken chassis have happened to some pretty good drivers.
I've seen these things flyin all over, hitting and getting hit by trucks, buggies, even 1/8 scales and Revos and still not breakin a chassis.
I've even seen Buggyking go cartwheeling and not break a chassis (yet).
I've also seen top level guys snap em just racin and mixin it up.
When that does happen, your day is over.
A brace, even if you have it and don't bolt it on will get you back on the track in minutes but you better have a top brace too cuz when the chassis goes, so does the top brace.
Then you're out a chassis and a top brace plus your race fee and a day at the track.
At least go make your own and have it ready.
I appreciate that you picked mine to run, thanks for the support.
You should buy a lottery ticket! You have a better chance of winning that than keepin your chassis together much longer.
You know I'm just bustin your balls again.
Man, you been fast, I'm gonna have to step it up again just to keep you in sight.
Or stay close enough to put the pressure back on you and get you to make some of those little mistakes.
F N CUDA is offline
Old 07-06-2009 | 08:44 PM
  #1870
BuggyKing's Avatar
Hey come on now. Lets be nice!
No need for insults there Cuda!
Old 07-06-2009 | 09:50 PM
  #1871
Just messin around tonight as always and i found that the 12mil hex adapters from my venom creeper fit on the rear roll pins.I havent actually drove it yet but it does fit pretty good.Might even be a better fit without that blue spacer but i'm not positive about that.Here is a pic for you to check out.
xv-townboy is offline
Old 07-06-2009 | 11:44 PM
  #1872
BuggyKing's Avatar
Hey Cuda,
Here is what u need to beat on Fri night.
Old 07-07-2009 | 07:07 AM
  #1873
F N CUDA's Avatar
Hey Cuda,
I'm gonna try to get past you using stock tires, if that don't work I may have to buy the cheater tires and see if I go faster too.
F N CUDA is offline
Old 07-07-2009 | 11:07 AM
  #1874
LoonyRacing's Avatar
Buggy,
How do you like those rears? I have some on the way...
LoonyRacing is offline
Old 07-07-2009 | 12:34 PM
  #1875
LWracer's Avatar
Default sway bars
Has anyone tried sway bars? Good/Bad?
LWracer is offline
