SC10 Thread
#8941
If the car is too loose on power, I add more toe at the hub carrier.
#8942
So, my FT SC10 is nearly complete (just waiting for my batteries to come) and I am noticing that my stock rear shock springs (silver) are kind of rubbing against the shock threads and is making a scraping type noise. The front's are fine, but both of the rear shocks make this noise. It doesn't seem like it would be a big deal, but I have read previous messages on here that say it is actually a pretty big deal. Therefore, what do you guys recommend I do to fix this issue? I suppose they could be dremmeled or what not, but I would honestly rather just buy springs that work right and don't need modifications. Should I switch to Losi springs or something, and if so, what color do you guys recommend? Thanks for all of the help!
#8943
I run The AE green springs in the rear on most of my car's. they don't seem to touch anything when compressed.
I have used the Losi Yellow/pink rear. the yellow caused a lot of push.
If you want to use the Losi springs
The upper collars I used are Traxxas # 3768 and the lower cups are Losi TLR5095
Springs for the rear are Yellow #5167 Pink #5168.
The green AE springs work well though.
#8944
The Losi BB springs won't hit.
#8945
#8946
Thanks man. Yeah, I'd like to stick with AE stuff, so I will probably just try the green springs you mentioned. That seems odd that the green springs don't rub but the silver ones do (I fully trust you though). I don't think I'm the only one who has issues with the silver springs though, seems like a common problem.
I am running Green rear and am going back and forth from Front Gold and Front Red.
Gold seem to push a little more but not as bouncy on the small bumps
#8950
#8953
So I have a question, how do I make this thing turn even sharper in the turns?
It seems maybe I just have to slow down more but I see other guys blazing through turns at my local track faster than me with no problems.
Can some people give me some tips? Should I set the suspension nosed over? I was going to add some weight to the front hoping that would help... I have good tires on the car, setup the suspension with 35/30 weight oil and blue rear/grey front springs. Overall it DOES turn well but I feel that there is something I'm missing...
Any ideas? If you need some more input from my end just ask.
#8954
I asked the same question with no luck on a answer. If/When you find out please post it, lol
That is what I do. but that small brake tap is causing time to be lost.
not a lot but after 24 laps it adds up. I am going to try a different camber link mounting spot in the back and keep the gold springs on and see how it does.
#8955
if they r different would i need different lower cups and collars?
