SC10 Thread
Old 11-22-2011 | 06:35 PM
  #8191
Muggydude's Avatar
Has anyone tried the contender body yet?
Muggydude is offline
Old 11-22-2011 | 07:56 PM
  #8192
Originally Posted by brent701
Well I looked at ROAR and found this
6.1.9 For closed-wheel bodies, no portion of the chassis, wheel, tire, or equipment
may extend beyond the body except to the rear
I am not sure that rule above really applies to a SCT or not but this one does
8.10.12.5.1 Full fender truck body. Body must completely cover tires when viewed from above
and Overall Width is Maximum 296mm (11.65 in)
With the STRC front HEX my tires can be seen from above the body. and I do not like the body hitting the tires when landing which in turn cuts slots in the tire
I do agree that a wider stance can help is handling to a point. You also have to redo your suspension setup to work with it.
all good and fun
So, my next question then would be which bodies sit are designed for maximum width of 11.65"? Thanks for the details...I really appreciate it.
Chris
ravencr is offline
Old 11-22-2011 | 08:01 PM
  #8193
HighLife420's Avatar
Originally Posted by njnewc
So what type of soldering Iron are you guys using? Also what Solder? My little iron is pissing me off and I think the solder I am using is too thick. It is like 5 years old and I don't even remember where and why I bought it... Thanks for the info...
just bought a hobbico 60w and some Novak Silver solder. Good stuff. Will get a better iron later, but as long as you keep the tip tinned, it should be good to go.
HighLife420 is offline
Old 11-22-2011 | 08:51 PM
  #8194
brent701's Avatar
Chris
I really do not know. There was a rule in there about the body and what needed to be on it.
I didn't read to far into all the rules. I never plan to race a ROAR event. I do not believe in most the rules. Our local tracks mainly use the Class rules so people do not need to change a lot of stuff (motors etc) I just checked my Pro Line Flow-tec body and it covers the wheels from above on the 2wd
brent701 is offline
Old 11-22-2011 | 09:16 PM
  #8195
Fair enough...I appreciate the help.
Chris
ravencr is offline
Old 11-22-2011 | 09:34 PM
  #8196
buzzbuzzard's Avatar
Originally Posted by stang
don't spread false info as my savox servo does fine without a cap. its not our fault spektrum can't build there rx's properly like futaba or even traxxas
I agree with you about Spectrum reciever's. Making the switch to Futaba after the Holiday's. However, Let's say you put a amp and subs in your 1:1. Everything works and sounds great. But durning certain frequency's and amplitude output. You notice your lights are dimming. Amp draw! Will it kill your car? NO. A Cap stores current. So when you get a brief moment of higher amp draw. The total electrical system has enough voltage to properly function. So even though you may not have encounter any issues. You most certainly would benefit from a cap.
buzzbuzzard is offline
Old 11-22-2011 | 09:37 PM
  #8197
brent701's Avatar
Chris
I tried to find some more info. I found this. and TBO, it made me a little mad lol
6.1.3.4 All approved bodies are required to have the manufacturer's ID and Body
number molded into the lower portion of the windshield or on the body below
the point where a windshield would have been on the full scale counterpart.
Otherwise, the proof of the legality of a questionable body is the responsibility
of the driver.
6.1.4 Throughout an event, the body must be complete, neatly finished, painted, and
trimmed. Detailed headlights, signal markers, grille and taillights appropriate for
each vehicle (where applicable) must be applied by paint or decal. These
details should be in significant contrast to the body in order to make them
clearly visible. No clear areas except windshields and windows are allowed. No
clear areas or stripes through body colors are permitted.
^^ Really? it's a damn RC car. lmao
I found a list for fuel off road bodies they do not allow.
Durango DNX408
JC Illuzion Ve8 HF
JC Illuzion MBX6
•PL Bulldog (All)
Serpent 811
Kyosho MP9 TKI2
Not able to find any SCT bodies though
I am not liking ROAR at all.
brent701 is offline
Old 11-22-2011 | 10:13 PM
  #8198
Muggydude's Avatar
Nobody likes ROAR...
Old 11-23-2011 | 04:44 AM
  #8199
Guys- What size drill bit do I need to fit Losi (rear) hub carriers on my SC10? I'd like to get everything in one trip...
OnlyVees is offline
Old 11-23-2011 | 05:54 AM
  #8200
My LHS didn't have any of the $6 cap's, so they sold me a $25 BEC and said it was better anyway. I am inclined to believe him but I like the sound of $6, but I don't mind $25 as long as it is the better option anyway.
vw addict is offline
Old 11-23-2011 | 06:36 AM
  #8201
Thanks Brent...No track driving for me again today, so until I really see what it's like on the track, I'm not going to mess with it anymore I don't think. After that, I'm sure I'll be doing some more tweaking.
Chris
ravencr is offline
Old 11-23-2011 | 08:01 AM
  #8202
I pull my caps from a old stereo power supply board. 4700uf 10v is the value of spektrum's glitch buster. The value needs to be AT or above this value. My current cap has a value of 6800uf 25v and it's free! Having a BEC is never bad. Just not really necessary if you are running a 2s lipo. 3s lipo and above you should have a BEC.
Old 11-23-2011 | 08:04 AM
  #8203
Will a BEC or a CAP prevent glitching? There loose power every now and then for a second in my SC10. This doesn't happen in my other cars. I'm using the same Airtronics radio in all of them. Any suggestions?
Delawareguy is offline
Old 11-23-2011 | 08:06 AM
  #8204
kc_nitro_rc's Avatar
The cap (capacitor) will prevent glitching. It stores energy kind of like a battery. Check your local Radio Shack or any good electronics supply store.
kc_nitro_rc is offline
Old 11-23-2011 | 08:54 AM
  #8205
Is glitching when you give it gas, then it locks up for a second then takes off again? Also, anyone have a picture or part number on a good capacitor and how to install it on a SC10? If this prevents what I described above, I'm going to do it, because it's annoying.
Chris
ravencr is offline
