SC10 Thread
Old 11-13-2011 | 08:57 PM
  #8041
Originally Posted by 20 SMOKE
this is what happens when the computer crashes before the mains,you put all the truck on the track at once
+ YouTube Video
Thank God for 2.4GHz!
Lansonfloyd is offline
Old 11-14-2011 | 07:44 AM
  #8042
Default Reedy ESC capacitor Question
Removed what appears to be a capacitor from my Reedy ESC. It is the component that is between the esc and the battery plug. Power was cutting out before removal and now works fine. Question is do I need to replace the component or not. Also, what is the function of the component. After removing, I ran the truck and no apparent glitching. I have also have a glitch buster between the receiver and 6040 spektrum servo. Thanks
Murray100 is offline
Old 11-14-2011 | 08:03 AM
  #8043
CraigMBA's Avatar
Originally Posted by HighLife420
haha...thats crazy 20Smoke...its like a demolition derby =)
I took 3rd in the stock 17.5 A-main today with my sc10. In fact, the first 4 were all SC10s. Setup very similar (minus pinion, tires). I had the 3 fastest lap times too. Broke a caster block on the last double and limped past the finish line in 3rd. Ill get them next week.
Think my setup is almost dialed in....motor temped no higher than 155F, even after 2 heats and some practice, running 26/75 gearing, have my motor timing advanced (end bell, MAXED), also running some dynamic timing (another 20 degrees @ 6k rpm).
Still having some rear traction issues though, didnt mess too much with my suspension, but it seems my rear likes to slide out alot on braking turns. What you guys think? I played with slipper a bit to to help control my take offs in the straights.
Add reare toe at the hub carrier. 1/2 to 1 degree.
CraigMBA is offline
Old 11-14-2011 | 08:11 AM
  #8044
Asharus's Avatar
Originally Posted by njnewc
What batteries are you guys using. I run a FT SC10 (17.5). I currently run 5000 25C Turnigy batteries. I want to upgrade, but I really don't want to break the bank. What do you suggest... Thanks
I use Xcelorin 60C 6000mah batts, mainly because my 4wd SC (SCTE) needs the high C and mah rating so I use those batts in all my vehicles. I'm considering the Revtech 65C 6500mah as my next batt though, they're slightly cheaper.
Originally Posted by brent701
I run a Savox 1258TG. 166 oz tq @ .08 speed @6v. I love it
works perfectly for me
+1, perfect for SC trucks, best bang for buck, but be careful, you may need a cap on your receiver to stop glitching/cogging. I run a spektrum cap in 2 out of my 4 Tekin RS setups, no cap needed on my RX8.
At least you finished your main. We had an 8 min A main in Pro2 Mod for a trophy race I attended this weekend. I was battling for 1st in the first 5 mins, and even took first place, but shortly after, a drive rollpin broke and I lost power to the left wheel. I couldn't even limp for the finish since there was at least 2 mins left. I was extremely upset, I even have the 12mm JC hex conversion. The last time I broke a rollpin was when I was still running the stock wheels.
Regarding your rear traction issues, what springs are you running in the rear, and what toe block are you running?
Asharus is offline
Old 11-14-2011 | 08:33 AM
  #8045
Sprinkler's Avatar
I have recently moved to using the 12mm hexes. I have the JConcepts aluminum hexes in the rear. What is everyone using for the front....the stock plastic RS hexes?
BTW....I have a huge pile of JConcepts White Rulex wheels with like new JConcepts Green DD's, Subcultures, Goosebumps and Bar Codes if anyone is interested. I will let them go cheap. They are for the stock setup which is bearings in the front and pin in the rear.
Sprinkler is offline
Old 11-14-2011 | 08:36 AM
  #8046
Asharus's Avatar
I still haven't been able to convert my fronts to hexes. I have way too many tires that have the stock bearing-in-wheel setup and will lose a ton of tires if I convert.
Asharus is offline
Old 11-14-2011 | 09:12 AM
  #8047
HighLife420's Avatar
Was thinking of that, will give that a try for sure.
I just bought that exact servo from hobby super store (local to me) for $60. I bought the cap just in case. I havent tried it without the cap, but its one fast servo. A tad loud though.
Im running the stock hub carriers, which are 0 i belive. Running the same setup as JR mitch (found here) This is the track i run at, same conditions.
HighLife420 is offline
Old 11-14-2011 | 09:13 AM
  #8048
20 SMOKE's Avatar
bake them off
20 SMOKE is offline
Old 11-14-2011 | 09:56 AM
  #8049
gamedog1966's Avatar
Default parts needed
hey there u guys and gals out there, i traded a rustler for a sc10 rtr but i want to kno what parts do i need in order to make it a ft truck and make it handle as well also?
gamedog1966 is offline
Old 11-14-2011 | 10:10 AM
  #8050
brent701's Avatar
I use the same rear hex and stock RD front hex.
brent701 is offline
Old 11-14-2011 | 10:11 AM
  #8051
brent701's Avatar
Yes, they are power hungry that is for sure.
Using a MMP need a BEC or glitch buster
Novak pro I do not need a BEC or glitch buster.
Stock RS ESC need a glitch Buster
brent701 is offline
Old 11-14-2011 | 10:38 AM
  #8052
ShortCourseOnly's Avatar
The power capacitor on the ESC is to filter the current through the ESC. I have fried an ESC cause the capacitor broke due to high current spikes going through the ESC. If you have a super high discharge battery it can supply whatever current your ESC delivers to the motor. Often times when you are running hard and hit the brakes you will spike the current feedback through the ESC and without the capacitor you will over current the FETs. So make sure you replace the capacitor.
What is the specs on your battery?
ShortCourseOnly is offline
Old 11-14-2011 | 10:39 AM
  #8053
Asharus's Avatar
seeing that you're already running 3 deg of rear toe, you can try running a softer rear spring (greens) or as per the suggestion above, add .5 to your rear hub carrier via the FT .5 deg aluminum hubs. bear in mind that you will need the larger outer bearing and a new crush tube if you go this route if you're still running the stock plastic hubs.
Asharus is offline
Old 11-14-2011 | 10:49 AM
  #8054
+1, for sure replace it...if its one of these.
Old 11-14-2011 | 11:44 AM
  #8055
Originally Posted by nadan805
I don't run any spacers with my savox.
Thanks man, I have to finish the installation up tonight. What are these glitch busters everyone has talked about? I turned my car on briefly to center the servo before installing the horn and I noticed it was going crazy. Looks like I'ma need to pick one up.
vw addict is offline
