SC10 Thread
Old 11-21-2011 | 01:42 PM
  #8161
Default Gens ace Brushless Sensored Motors
Hi
Has anybody tried the motors from Gens Ace in the AE SC10...?
racerkorer is offline
Old 11-21-2011 | 01:53 PM
  #8162
Originally Posted by Lansonfloyd
IMO the stock steering servo is trash. I had the exact same symptoms, swapped to a modest Hitec digital for $45, and ran into a lot less of a problem. Car still has issues turning while accelerating, but I just figured that was normal for the breed.
That's kind of what I figured. When you say a modest hitec digital, any ideas on what model numbers would work well with essentially a stock SC10 otherwise but not underpowered either? Do I need to look for a specific level of torque or something else?
Chris
ravencr is offline
Old 11-21-2011 | 01:55 PM
  #8163
Originally Posted by kc_nitro_rc
You need to drill holes in the front tires so the air can pass thru them allowing them to turn.
Are you being serious?
Chris
ravencr is offline
Old 11-21-2011 | 03:45 PM
  #8164
Chris
For me it was the Hitec HS5625MG. $45 at Hobby People locally.
Savox 1258TG would be better by a country mile for only a few bucks more, but you may need to get a BEC, a cap, or some other extra thing to get it to work right. That's because the Savox servo has a lot more amps to pull and the ESC you're running just may not handle it. Still, if you wanted to kick ass and take names, the Savox wins. For me, I only had ~$50 to spend and I wanted one "right now", so the Hitec was for me. I'll probably swap out for the Savox later.
Lansonfloyd is offline
Old 11-21-2011 | 07:46 PM
  #8165
Because I'm a complete Newbie, can you explain what a BEC, a cap, and what that other thing may need to be potentially? I hate buying new parts that I'll regret again in the future, because it wasn't quite enough, if that make sense.
Chris
ravencr is offline
Old 11-21-2011 | 08:28 PM
  #8166
Are you running a 4.5 in your 2wd SC10 or SC10 4x4? A 4.5 is a lot of motor for the 2wd SC10. I put a 6.5 in mine and de-tuned it with my ESC. It's still a lot of motor! Your 8.5 should be perfect unless you are trying to set some speed record out on the Salt Flats of Utah.
dude not cool. I was drinking something when I read this reply and bout choked to death. anyway, I was trying to run it in my 4x4 with a 12t pinion 62t spur 38 pitch. can someone explain what the different pitches do for your vehicle? I figured it was bigger gear for the more weight than a 2wd. and does the bigger pitch put more strain on your motor? and what are the advantages to running either pitch.
slammin1984 is offline
Old 11-21-2011 | 08:37 PM
  #8167
HighLife420's Avatar
anyone else having problems stripping wheels with the pins? Ive gone through 3 wheels so far...ive loosened the slipper a ton and it still strips.
HighLife420 is offline
Old 11-21-2011 | 08:49 PM
  #8168
brent701's Avatar
Upgrade to Hex
brent701 is offline
Old 11-21-2011 | 08:54 PM
  #8169
brent701's Avatar
Chris
BEC = Battery Eliminator Circuits
Cap = capacitor It's like a battery. it stores power
the Savox servo draw a lot of amps. which if you turn one lock to lock it will turn the receiver off which makes you lose all power to the truck.
CAP or glitch buster is the cheapest way to go. 6 bucks. I have two in my trucks and they work perfect. I have also ran a BEC. this in a way is the same thing but different
I used a CC BEC and used it to power the servo alone. it was adjustable so I can adjust the speed /TQ of the servo by the voltage 4.8v or 6v .
My 4x4 with a MMP ESC has to have a CAP
My 2wd with a Stock ESC has to have a CAP with the servo
My buggy with a Novak. does not need a add on cap like above. the ESC already has one wired to it.
If need I can post a pic of one installed in my truck
brent701 is offline
Old 11-21-2011 | 09:28 PM
  #8170
skengines's Avatar
Anyone have the part # for the spacer that goes in the front arm? It says 7922 but that is for the caster block only.
skengines is offline
Old 11-21-2011 | 09:44 PM
  #8171
don't spread false info as my savox servo does fine without a cap. its not our fault spektrum can't build there rx's properly like futaba or even traxxas
stang is offline
Old 11-21-2011 | 10:27 PM
  #8172
monty c's Avatar
From: Dont get any more northwest than me..........
i have 2 savox servos, the one in my SC10 with normal sized spektrum reciever has had no issues, the one in my 22 buggy with the micro reciever had issues all the time, i would get about 2 minutes into a run and the whole car would shut down, couldnt figure out what was going on until i started reading about the savox servos being power hungry, installed the cap and problem fixed.....
monty c is offline
Old 11-21-2011 | 10:31 PM
  #8173
monty c's Avatar
i stripped out a left rear, the nut would keep coming loose and let the wheel spin. keep fresh wheel nuts on hand, seems like the nylon wears out fast and they wont stay tight. i take them off every run to clean the tires and they nylon doesnt last long.
monty c is offline
Old 11-22-2011 | 12:06 AM
  #8174
Wild Cherry's Avatar
Tech Legend
Use the steel wheel nut, make sure they have been kimpled or have little dents on the top on the nut to add pressure to the nylon .
Some don't have these little dents and those do not have the grip you need and can come loose.....
Wild Cherry is offline
Old 11-22-2011 | 03:41 AM
  #8175
Also, you could get the Jconcepts wheel nuts. They have serrated edges on the back side. I switched to these, and have not had a problem since. I went through about 8-10 of those nylon locknuts before I switched. They may seem expensive at the time of purchase, but you make that money back pretty quick by saving your wheels.
outlawrcgraphic is offline
