SC10 Thread
Old 01-12-2012 | 12:15 PM
  #8971
HighLife420's Avatar
Im guessing mine are the b44 ones, since it has the larger outer bearing.
I think i can use ASC7933.
HighLife420 is offline
Old 01-12-2012 | 04:10 PM
  #8972
njnewc's Avatar
Brent. I ordered that case 9826 and the diff has an 1/8 inch slop. I have 3 other ball diffs in other cars. This is def not the right case. The package even said gear diff. I ordered everything by part number out of the factory team parts breakdown for the sc10. It's weird.
njnewc is offline
Old 01-12-2012 | 04:12 PM
  #8973
Registered User
I would just say to, call AE tomorrow
Ryno B4.1 is offline
Old 01-12-2012 | 04:22 PM
  #8974
i would like to hear your results because my ball diff is super loose too and wobbles alot! even my brothers gear diff has some play but this is just ridiculous i'm not sure what the deal is, mine is an original kit built with the ball diff upgrade
Biznak is offline
Old 01-12-2012 | 08:02 PM
  #8975
JEFFs SC10's Avatar
What Losi BB springs are equivalent to ae greens for the rear and. Red/ gold/ blue for front?
I want to try the conversion this weekend.
TIA
JEFFs SC10 is offline
Old 01-12-2012 | 10:29 PM
  #8976
brent701's Avatar
TIA
Yellow is 2.00 lb
White is 1.80 lb
brent701 is offline
Old 01-12-2012 | 11:05 PM
  #8977
ChadB.'s Avatar
What glue is everyone using to glue there servo saver?
ChadB. is offline
Old 01-12-2012 | 11:32 PM
  #8978
aSab's Avatar
Originally Posted by brent701
Plastic hub spacers are #7377
If you use the alum. hub spacer in the plastic hub the bearings will give. Mine lasted 3 5min heats and the left rear stopped moving.
I also run the B44 rear hubs but without any crushtubes, and my bearings do hold up fine.
aSab is offline
Old 01-13-2012 | 06:16 AM
  #8979
kc_nitro_rc's Avatar
Same thing you use to glue tires.
kc_nitro_rc is offline
Old 01-13-2012 | 06:54 AM
  #8980
Asharus's Avatar
TIA
Now that the 22T is out, maybe we'll have some springs we can use for the front of the SC10. I'm excited to see some new setups with the Losi BB springs.
Asharus is offline
Old 01-13-2012 | 10:27 AM
  #8981
ChadB.'s Avatar
Oh ok, I didn't think tire glue would bind it together so it wouldn't break apart again on the track.
ChadB. is offline
Old 01-13-2012 | 10:39 AM
  #8982
Did I miss something? Is this before or after it breaks?
Mark
mark in wi is offline
Old 01-13-2012 | 03:29 PM
  #8983
Chad Smith's Avatar
What is the purpose of gluing the servo saver togethor?
Chad Smith is offline
Old 01-13-2012 | 03:37 PM
  #8984
bds81175's Avatar
Moderator
If you have a strong servo with metal gears its a mod a lot of people do. It makes the truck feel much more direct, especially on high bite and through bumpy sections. Its a noticeable difference. Do do it if your servo is questionable.
bds81175 is offline
Old 01-13-2012 | 05:55 PM
  #8985
JEFFs SC10's Avatar
I downloaded the 22t manual and they use green springs in front part no tlr 5182
and rears are pink part no tlr 5168.
So hopefully my lhs has these in stock.
