SC10 Thread
#9722
Clutch basket off of my 4x4. I too saw a pic of it mounted to a b4. it doesn't work. I couldn't get the nut loose enough. and it pop my idler on my bench. I don't make this stuff up.
#9723
any one know much about this carbon fiber chassis ?????????
http://www.bartspartsrc.com/sc10parts.html
#9726
Attachment 875481
Attachment 875481
#9727
Garodiscs maybe? Come to think about it...
#9728
Oh, so your saying that you don't completely replace the rings inside your diff. whenever you rebuild it? You just simply sand down the diff. ring and the thrust washers, and then reassemble? This is all granted that I am using both ceramic thrust balls and diff. balls, not the stock carbide diff. balls and steel thrust balls.
Rings are not expensive , flip um once to use the other side and then replace after ...
Ae diff rings come polished and do not need sanding....
Sometime I have found a ring or two that could use a sanding , but that does not happen but rarely ....
#9729
So I don't know a ton about exactly how this slipper should be set. But im confused about what's wrong with the stock top shaft that a longer would help. Are you saying that the soring is still to tight with stock type settings? Or is this just an issue with the new slipper parts?
#9731
I was thinking about this a while back when I first got the MTK basket for my 4x4. But felt it might only be beneficial if I ran a mod motor on my 2wd and B4.1 but I'm only 17.5. I guess 1Fastpede already gave it a go
#9732
#9734
I am looking around for a set of good looking wheels for a SC10. Can anyone point me in the right direction where I could get chrome or black chrome wheels from?
I had a look at HPI, but I am unsure which ones would fit.
