SC10 Thread
Old 05-24-2009 | 09:58 PM
  #1441
JEB21's Avatar
Is the newly released RTR car the same as the kit? Any upgrades that the kit has that the RTR doesn't? My local shop has a good deal on the RTR this holiday weekend. Thanks!
JEB21 is offline
Old 05-24-2009 | 10:17 PM
  #1442
Ephidelt490's Avatar
Buy it . Truck is awesome.
Ephidelt490 is offline
Old 05-24-2009 | 10:22 PM
  #1443
hey John,
the RTR is the same as the kit. I'd buy the RTR. if nothing else you could sell the radio, ESC, and motor for $50 and have a killer pre-painted body. See you at freedom park tomorrow
backyardracer is offline
Old 05-24-2009 | 10:23 PM
  #1444
R40Victim's Avatar
If there's a difference, I haven't found it, aside from the extra spur... It appears almost exactly the same.
http://67.199.85.166/ae/sc10/sc10_home.php
R40Victim is offline
Old 05-24-2009 | 10:32 PM
  #1445
The RTR comes with the $60-$70 Pre-Painted body and radio gear. Not too much different than that.
AE R&D is working on a fix for the wheels as we speak.
Old 05-24-2009 | 10:58 PM
  #1446
R40Victim's Avatar
What's the problem?
Old 05-24-2009 | 11:39 PM
  #1447
There is a hollow section in the wheel hex. The wheel pin will eat into the void in the wheel, which will crack and break the thin plastic layer. Once that happens, the drive pin eats up the entire hex.
The best fix I have come across is to fill it with JB Weld from the get go or "rebuild" the torn up slots with JB Weld.
Old 05-25-2009 | 03:22 AM
  #1448
Sith Lord's Avatar
Looks good Sith .
If you are running on an outdoor, dry track I have a few suggestions. Dremel the tabs off your battery strap so you can mount the battery to the rear of the truck. Use the Gold Front springs with Black Rears (if it's REALLY loose, otherwise leave the Greens). I run #2 Pistons the entire way around with 30 wt. AE oil. Stock shock limiters front and rear. Bones level front and rear; LOWER the rear ride height by 3-4mm if it's really loose.
Dremel your stock tires to add side bite. Cut a groove in the outside lugs as shown.
Easiest way is to just mount up the JConcepts Goosebumps .
Cheers. Don't know what AE were thinking with the Battery strap. I had to dremel quite a bit off near the twist knobs. Have also drilled big holes near the rear to mount it towards the rear too.
Sith Lord is offline
Old 05-25-2009 | 10:18 AM
  #1449
KidAgain's Avatar
You need to make one of these This way you can run any configuration and battery.
KidAgain is offline
Old 05-25-2009 | 10:37 AM
  #1450
BuggyKing's Avatar
Looks like a spinoff from mine.
BuggyKing is offline
Old 05-25-2009 | 10:39 AM
  #1451
KidAgain's Avatar
Matt where do you think I got the idea from. No way in hell was my battery gonna work with the factory strap.
KidAgain is offline
Old 05-25-2009 | 10:40 AM
  #1452
BuggyKing's Avatar
I too know that strap wasnt gonna work from AE.
But made some changes to my suspension since then.
Old 05-25-2009 | 10:58 AM
  #1453
KidAgain's Avatar
Nice, will have to pick your brain again. Check out my sc10 action shot thread on page 2.
KidAgain is offline
Old 05-26-2009 | 06:56 PM
  #1454
Robertw321's Avatar
That's 2 T4 straps, right?
Robertw321 is offline
Old 05-26-2009 | 07:32 PM
  #1455
KidAgain's Avatar
t4 and a b4 with factory team thumbscrews, the rear studs you will have to make or find your own cause the originals are way to short.
Jake
KidAgain is offline
